Basement Stairs - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 09:04 AM   #1
Basement Stairs
How can i eliminate the squeaky, noisy wooden stairs leading into the basement before i carpet them. I was thinking of adding some blocking in behind the stairs from underneath if that would work, thanks.
Dave
fax6202 is offline   Reply With Quote
Old 05-01-2012, 10:10 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Dave
If they are that squeaky they shouldn't be too hard to take up glue and reinstall unless they are mortised in type stairs. If they are you can cut wedges and glue both side of the wedge and drive them in the mortise to tighten the steps.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-01-2012, 10:12 AM   #3
they arent terrible but enough to make me want to fix it, i would prefer alot more solid feel. and they are mortised so i will go with your advice. thank you
The Following User Says Thank You to fax6202 For This Useful Post:
BigJim (05-01-2012)
Old 05-01-2012, 10:49 AM   #4
Rewards Points: 12,804
If there just nailed in place then why not just predrill and counter sink and add screws?
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 10:13 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
