Basement Soffit Advice - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-11-2007, 11:58 AM   #1
I have 2 HVAC ducts that run down the center of my basement, with a beam about 4' away. I would like to put them all in one 7' soffit, but I don't know the best way to do it with the following goals and limits.
1. I'm using 5/8 rock on the ceiling.
2. I want to maximize headroom...the bottom of the lowest obstruction is at 7' 1".
3. I am planning on putting can lighting in the space between the ducts and the beam.
4. My inspector stated that on long soffits like this, they need to be fireblocked every 10' along the run...I have no idea how to accomplish this.
5thQuarter is offline   Reply With Quote
Old 02-14-2007, 12:37 PM   #2
I supposet this is what you mean fire block
I suppose you mean instead of a hollowed soffet (in area in between the two trunks) as you combined the two trunks into one soffet, inspector said you need to seal it every 10' along the run...there must different ways to do this... I think the first question to ask is what material are you going to use to insert every 10 feet for blocking the fire... one idea is using regular 5/8 drywalls... ... so I suppose if this is the case, all you need to do is setup proper wood studs in every 10' or less inside the truck frame for you to hang those drywalls.... after you do all framing and electrical...
KUIPORNG is offline   Reply With Quote
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
soffit in basement DIY4EVER Building & Construction 2 06-18-2007 09:05 AM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
