-   -   Basement Soffit Advice (http://www.diychatroom.com/f15/basement-soffit-advice-6443/)
5thQuarter 02-11-2007 12:58 PM
I have 2 HVAC ducts that run down the center of my basement, with a beam about 4' away. I would like to put them all in one 7' soffit, but I don't know the best way to do it with the following goals and limits.
1. I'm using 5/8 rock on the ceiling.
2. I want to maximize headroom...the bottom of the lowest obstruction is at 7' 1".
3. I am planning on putting can lighting in the space between the ducts and the beam.
4. My inspector stated that on long soffits like this, they need to be fireblocked every 10' along the run...I have no idea how to accomplish this.
Ideas?http://photos1.blogger.com/x/blogger...3/P1030574.jpg
KUIPORNG 02-14-2007 01:37 PM
I supposet this is what you mean fire block
I suppose you mean instead of a hollowed soffet (in area in between the two trunks) as you combined the two trunks into one soffet, inspector said you need to seal it every 10' along the run...there must different ways to do this... I think the first question to ask is what material are you going to use to insert every 10 feet for blocking the fire... one idea is using regular 5/8 drywalls... ... so I suppose if this is the case, all you need to do is setup proper wood studs in every 10' or less inside the truck frame for you to hang those drywalls.... after you do all framing and electrical...
