Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-03-2012, 12:18 PM   #1
basement shower question
Basement is roughed in for shower. Hole is approx 2 feet by 2 feet. Pipe is ready for shower drain. My question is do I have to concrete over the hole and leave the pipe standing(like the concrete is poured around the toiler drain) or can I just fill the hole with stone, and frame the subfloor panels over it?
newfieblue is offline   Reply With Quote
Old 12-03-2012, 09:05 PM   #2
I suggest that you repair the concrete slab (put plastic down before you pour the concrete. It will assist in keeping down dampness (if that is a problem) and support the shower base or subfloor and shower base. Test the waste line first.
TheCamper is offline   Reply With Quote
The Following User Says Thank You to TheCamper For This Useful Post:
newfieblue (12-04-2012)
Old 12-03-2012, 10:32 PM   #3
Its possible that the ground water level could rise and water to flow up through the stone and leading to flooding of the basement.
The opening should be sealed, as is the toilet!
The Following User Says Thank You to Wildie For This Useful Post:
Old 12-04-2012, 12:38 AM   #4
Super Moderator
What kind of pan are you installing? Is the drain pipe 2"----A large opening is often left for a tub---but seldom for a shower---
Old 12-04-2012, 06:05 AM   #5
I will be installing a maax shower kit. There drain is a 2" as required for this shower kit.
Old 12-04-2012, 06:23 AM   #6
Super Moderator
Fill with gravel----then,as you are installing, top the hole with some masons mortar----
You will want to put some mortar under the pan to properly support it---there is an advantage to having a bit of wiggle to the pipe===it's much easier to set the drain if the pipe can be moved a bit.
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 06:11 AM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 03:55 PM
Basement Shower Backup robbdc Plumbing 0 12-15-2009 09:22 AM
Mold growth in basement under shower. Need suggestions to fix leak and clean up mold vseven Plumbing 6 12-10-2009 03:33 PM
