Basement Shelves - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2013, 10:13 AM   #1
Rewards Points: 1,050
Basement shelves
Hello
I'm planning to clean up my basement () and I want to build shelves out of studs (2x4) and OSB
Length will be 8' and width 18" - planning to use only 4 legs
For the OSB, can I use 7/16" or I really need to use 1/2" ?
Home Depot has 7/16" boards at a good price (~$8 for a 4x8 sheet)
For me, most of the weight will be supported by the studs, not really the OSB itself, especially with shelves that are "only" 18" width....
french_guy is offline   Reply With Quote
Old 11-30-2013, 10:50 AM   #2
Framing Contractor
Rewards Points: 118
If your basement has any moisture at all, I would use plywood instead of osb. They will hole up much longer. If it is dry, you are ok with osb. Making the shelves 8' with no center support makes them likely to sag if you load them up. Consider a center support. Either add a leg of possibly an angled bracket
sixeightten is offline   Reply With Quote
Old 11-30-2013, 02:26 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
framing makes one good point.. the other being osb leaves has really ragged edges when it gets cut and youll tear up your hands along them.. plywood you can atleast and the edges of or put a edging on
woodworkbykirk is offline   Reply With Quote
septic pump for basement toilet denemante Plumbing 4 02-13-2013 10:42 AM
Small basement ventilation and insulation stevefrench Insulation 2 12-05-2012 09:08 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
