Basement Renovation 2x4 Vs 2x3 And Using XPS - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 03:38 PM   #16
Originally Posted by Out2pasteur View Post
What is your plan for flooring/sub flooring?
Not sure if you're asking me, or the original poster. I'm still researching, but I'm currently thinking of vapor barrier, then 3/4" XPS foam, then Advantech subfloor, then a floating engineered hardwood floor.
Rekonn is offline   Reply With Quote
Old 05-21-2013, 01:02 PM   #17
Originally Posted by Rekonn View Post
Nice, I have a walk out basement that I'd like to finish someday too. I'm also thinking rigid foam and 2x4 framing, but using Roxul for cavity insulation.
Exactly what i am going to use. Hopefully the Roxul is not overkill with the 2 inch XPS. What you doing for subfloor?
thenewkid is offline   Reply With Quote
Old 05-21-2013, 01:33 PM   #18
I'm in MA, and to meet the requirements LINK, I'll need R13 continuous or R17 cavity. I'm using the exterior wall numbers because I have a walk out basement where at least half of the walls are above grade. I'll check with my local inspector to make sure before I buy anything, but those are the numbers I'm starting with.
Yup, it could be overkill. What's nice about doing it on my own, is I can put up XPS first, and see what it feels like in the winter with just that. I might decide the XPS alone is good enough.
I really don't know what I'm doing with the floor yet. I don't have a good handle on what R value I should shoot for. On the low end, I'm thinking of using DMX 1 step underlayment LINK. According to them, that's an R value of 2.2, has got the vapor barrier built in, and I can put a floating engineered hardwood floor right on top.
On the high end, I'm thinking some vapor barrier, then 1" XPS foam R5, then floating hardwood. Earlier I was thinking Advantech subfloor over the XPS, but I think that's only needed if I have to nail down a hardwood floor.
Old 05-21-2013, 02:12 PM   #19
bryanp22's Avatar
Rewards Points: 290
Do your local building codes still allow vapor barrier? My inspector says no vapor barrier. I'm leaning towards no XPS with a 1/2 gap between 2x4 and wall and then just using R15 roxul.
bryanp22 is offline   Reply With Quote
Old 05-21-2013, 02:17 PM   #20
Also in MA and checked with my inspector and was told if i get R10 on the basement walls don't need any insulation between the 2x4 but it is my option. Was also told that dricore could be used and if wall is on dricore no PT wood is required since not touching cement. Wanted me to stay away from using PT in basement if possible. Thanks for the info on DMX-1 going to look into it just don't know if that will allow water to flow to my subpump in case i do get water up from the floor.
Old 05-21-2013, 02:34 PM   #21
Cool, add your location to your profile! Is your basement walkout, or all below grade?
Old 05-21-2013, 02:47 PM   #22
I don't know, haven't contacted them yet. I've never contacted an inspector actually. I have read that leaving a gap is a very bad idea LINK. Roxul make a board product if you don't want to use XPS behind the 2x4s.
Old 05-21-2013, 07:18 PM   #23
It is a walkout basement and really only front is below grade ..
Old 05-21-2013, 09:10 PM   #24
bryanp22's Avatar
Rewards Points: 290
So what thickness xps is minimum requirement in zone6?
Old 06-10-2013, 08:23 AM   #25
Sorry for not responding. I must have missed the email notification showing there were some replies to my thread.
As far as the stairway, my plans are to move this stairway. The current location will interfere with the future master bedroom.
As far as the flooring, my plans were to seal the concrete, use a vapor barrier, insulation/padding, and carpet. Is this a bad idea?
Last edited by jruppert; 06-10-2013 at 08:24 AM. Reason: I just realized I had a different account on this site. Odd...
jruppert is offline   Reply With Quote
