Basement Reno Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 02:11 PM   #1
basement reno question
Framing out basement, running electric now, whats the best way to.heat these two rooms? If I pull off of existing duct work it probably will drain top two floors,...go with space heaters? Wall mounts? Gas is available, venting is an issue, need suggestions.......live in new Jersey....only need to heat 3 or 4 months out of the year
Remod11 is offline   Reply With Quote
Old 02-28-2012, 03:01 PM   #2
MarginallyQualified
Rewards Points: 2,464
The term "best" is highly subjective. That said:
Insulate it REALLY well... and then add a few electric baseboard heaters.
Old 02-28-2012, 05:41 PM   #3
got little ones so I dont want hot baseboards on the floor where their going to crawling around. How about wall mount space heaters? They seem to put out way more heat and have a fan in them. Not a problem to install but are they a fire hazard? or is that a just because stupid people leave stuff in front of them so they actually create a hazard??...
Old 02-28-2012, 05:43 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
We often do wall mounted heaters in smaller mudrooms and smaller basement area renovations (can also be bought with thermostats). If you want to do a gas unit, then contact a reputable & qualified person to install such a unit. Bare in mind, that you will still need to get a gas-unit's controls wired electrically.
- Build Well -
Old 02-28-2012, 07:31 PM   #5
Rewards Points: 512
if the price is at no concern go with a convention heaters http://www.convectair.ca/caen/produi...gro.html#fiche convectair is suppose to be the best out there. they basically invented them. i'd have them in my own house if i could afford them
princelake is offline   Reply With Quote
Old 02-28-2012, 07:50 PM   #6
So you think that wall mounted space heaters would be fine for 2 rooms there both 12 by 12....then a small bathroom....
Old 02-29-2012, 06:54 AM   #7
1 per room. You don't want to sit on an ice-cold throne.
- Build Well -
Old 02-29-2012, 10:24 AM   #8
Rewards Points: 512
on average 10watts for every square foot. figure out how much space you have and buy what you'll need per room.
Question on basement wall/foundation height iub98 Building & Construction 6 07-15-2012 11:15 PM
Basement bath framing question. oba97 Building & Construction 2 02-02-2012 01:58 PM
Unique basement insulation question gunner74 Insulation 3 12-01-2011 09:11 AM
Running Wires From Basement Question reb162 Electrical 5 06-11-2010 05:08 PM
finishing basement question fabian Building & Construction 6 06-19-2009 12:59 PM
