Basement Remodel Steps - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-10-2013, 03:39 PM   #1
bryanp22's Avatar
Rewards Points: 294
My basement is framed and I'm having an electrician come later this week for the rough electrical work. Can anyone just confirm the order of work for me. Just want to know I'm doing this in correct order
Insulation
Drywall
Install door
Drywall Taping and mudding
Painting walls and ceiling
Finish electrical
Install flooring
Install baseboard and trim.
bryanp22 is offline   Reply With Quote
Old 09-10-2013, 05:04 PM   #2
DIY staff
Rewards Points: 7,174
Frame
--plumping and electrical rough
---Insulation---
Drywall---hang/tape/sand/prime
Hard flooring--tile or other--sheet goods/laminate
All trim work---doors--window jamb extensions--cabinet work(if any)
Casing /base molding
Caulk---putty---touch up drywall---final paint--two coats of good paint
Electrical switches/outlets---light fixtures----hand rails---
Carpet
Old 09-10-2013, 06:28 PM   #3
bryanp22's Avatar
Rewards Points: 294
Thanks. I was having problems finding this on google.
Old 09-10-2013, 06:43 PM   #4
DIY staff
You want to avoid installing things that could be in the way or damaged by the upcoming work----
A common mistake is to install the switches and outlets before the drywall and paint---the tabs in the outlets are in the way of the drywall---and must be broken off in order to get the drywall in place---
If doors are installed before the flooring---the jambs need to be cut in place in order to slip the flooring under them---
Every time a mistake like that is made--time is wasted--and the possibility of damaging a finished product increases.
Basement Remodel - Whats the Order? LMNO Building & Construction 7 12-29-2011 06:24 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Basement remodel, help with an efficient layout? (diagram incl.) Dave88LX Remodeling 1 11-10-2011 03:36 PM
Outside basement steps drain clog sillyboy22 Plumbing 0 07-21-2010 07:09 PM
Basement Remodel dOe Building & Construction 9 04-01-2010 10:01 AM
