Basement Remodel Help With Ductwork - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 01:57 PM   #1
Basement Remodel Help with Ductwork
I am looking at finishing out my basement and need help with how close can I get to the ductwork. The bottom of my ductwork is 8ft to the floor and I have a window in the basement where the height is 7'8" from the floor, so I have 4 inches of play if I go all the way to the ductwork. My question is how close can I build something next to the ductwork. I know all building codes are local; however I can not seem to find any codes in regards to this issue, any help would be greatly appreciated.
buildit45 is offline   Reply With Quote
Old 11-16-2011, 04:36 PM   #2
Rewards Points: 5,336
There's no distance required. It's not like the wood will burn. You just want it far enough away so the ducts don't touch the framing. You can get it 1/2"-1" away to be sure.
Are the ducts insulated?
Ron
B. Franklin 1759
Old 11-16-2011, 07:49 PM   #3
Thanks for the information. The ductwork is not insulated.
Old 11-16-2011, 08:35 PM   #4
It should be.
Ron
B. Franklin 1759
Old 11-16-2011, 09:13 PM   #5
Seal all joints in the duct work with metal tape or seam seal. Do not use cloth duct tape. I agree that you should insulate the ducts as well.
As far as the distance - it only needs to be far enough away so that the ducts don't hit the new ceiling if they expand and contract in operation.
Evstarr is offline   Reply With Quote
Tags
basement , ductwork , soffit
Ideas For Basement Bathroom Remodel DrHicks Kitchen & Bath Remodeling 8 01-21-2011 04:53 PM
Cinder Block Basement Remodel raxtman Building & Construction 7 07-16-2010 02:37 PM
Finishing basement, had a few questions about ductwork... Wyjeep Plumbing 12 04-27-2010 10:27 PM
Basement Remodel dOe Building & Construction 9 04-01-2010 11:01 AM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
