Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-26-2012, 11:12 PM   #1
Basement refinishing, which subfloor is best?
I am starting to finish my basement, and would like to get some opinions regarding the various types of subflooring products. I plan to use Pergo type, or similar, finished flooring. Moisture retention and mold prevention are important. DriCore looks interesting, but if it gets wet could it be a problem? Would I be better off using something like Tyroc, or DeltaFL, products that are inorganic and thus won't absorb water? I read an article in Fine Homebuilding #169 pages 78-83 that suggested laying 1" EPS rigid foam directly on the concrete floor, then sealing it, followed by 2 layers of plywood. This doesn't seem to allow adequate air circulation between the concrete floor and the subfloor. Also, what would be the best way to wall over the poured concrete walls? That article also recommended installing 2" EPS directly on the walls, then putting up wood studs. Also, should I do floor first, then walls? Any advice for this newbie would be appreciated.
AlBhandy is offline   Reply With Quote
Old 03-27-2012, 03:21 PM   #2
I just had my basement done. My concrete was pretty smooth though a little "wavy" per the flooring guy. I sealed the minor cracks with a self leveling compound prior to install. They just used a pad with a vapor barrier under the laminate. I obviously don't know how it'll work out but I did check with a few flooring stores, also expressing my concern about moisture, and they were consistent in recommending the same thing.
Good luck!
canoes is offline   Reply With Quote
Old 03-27-2012, 06:22 PM   #3
dricore is the way to go. i wouldnt recommend putting vapour barrier on the floor
princelake is offline   Reply With Quote
Old 03-27-2012, 11:21 PM   #4
Moderator
You don't want air getting to the slab: fig.10: http://www.buildingscience.com/docum...ms?full_view=1
Photo 3: http://www.buildingscience.com/docum...g-your-basment
I personally would not recommend OSB anything around water or moisture.
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Old 05-06-2012, 08:32 PM   #5
dricore? osb? concrete acid stain? I wish I knew what to use!!!!
jayinwww is offline   Reply With Quote
Old 05-07-2012, 02:55 AM   #6
I was planning on using Dricore but chose acid stain instead. The cost per square foot is much less, it's not going to be damaged by water, it's easy to repair, it doesn't reduce ceiling height and looks really cool. The prep. however was very labor intensive but for a buck per square foot, it was worth the effort.
vcheez is offline   Reply With Quote
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 02:13 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
