Basement Refinish Framing/insulation Questions - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 12:17 PM   #1
Basement refinish framing/insulation questions
Hi folks, I'm just about prepped to start this project. This is a full-height basement, not a walk-out. Block walls, full drip-edge slab. It's been recommended that I install the vapor barrier against the block wall with the bottom tucked into the drip edge. That makes sense.
On the two walls that carry the main waste, I plan on framing about a foot way from the wall to hide the main waste obviously, and also the pump-out box in the bathroom area. I was going to frame in metal, but reading here indicates a bit more difficulty to attach battens in the areas where I'll be framing away from wall. So would the recommendation be to simply frame out in lumber?
The remaining wall areas have no mechanical and I can frame against the exterior wall.
So, faced with this type of project, would it simply make sense to frame completely in lumber?
Thanks.
Ultrarunner is offline   Reply With Quote
Old 01-20-2012, 08:51 PM   #2
Rewards Points: 2,212
do a search for basement insulation on the forum. Basically use 2" styrofaom then your wall. Building science website has lots of info.
mae-ling is offline   Reply With Quote
Old 01-20-2012, 09:05 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I would stick with wood, but that's just because I'm a carpenter, not a metal worker.
titanoman is offline   Reply With Quote
Basement Trap and confused questions Ryan7 Plumbing 15 02-26-2011 10:42 AM
Adding heat to a basement, newbie questions frizbplaya HVAC 3 01-28-2011 02:57 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
