Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-10-2012, 02:51 PM   #1
Basement insulation with 2x4 walls already framed
I recently bought a house with an unfinished basement. The former owner had started finishing it, but didn't get far. He did put 2x4 framing up along the outside poured concrete walls, but only left about half an inch of space between the studs and the concrete. I guess his plan was to insulate with fiberglass batt insulation.
I would like to avoid ripping out the framing, but do not want to insulate with fiberglass. What is my best option? Can I do rigid foam board between the studs and push thinner strips of foam in the half-inch space between the studs and concrete?
What about those home spray foam kits?
Thanks for your help
topaz75 is offline   Reply With Quote
Old 10-10-2012, 08:12 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
by code there has to be a air space behind the framing so the studs dont touch the concrete and to allow breathing
woodworkbykirk is offline   Reply With Quote
What to do with basement walls. RR. Remodeling 3 02-20-2012 07:49 PM
Insulate rim joist & basement walls- if exterior walls have no insulation? cbrc5eric Insulation 5 02-01-2012 08:47 AM
Yes, Another Basement Insulation Question Beepster Insulation 7 11-30-2011 07:30 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
