Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-02-2012, 09:36 PM   #1
Basement insulation - 2 walls
I'm finishing only a section of my basement.. so basically a quarter of a rectangle...
I plan on putting ridgid insulation against the two concrete walls.. but my question is what to do for insulation for the other two walls, which will be shared by the unfinished parts of the basement.
Should I just go with unfaced fiberglass and call it a day?
chigundo is offline   Reply With Quote
Old 04-02-2012, 10:11 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Insulate all the same, and you have to cover the XPS with Gypsum, due to it will give off toxic fumes if it burns.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Need opinions on insulation of basement walls mstemphoski Building & Construction 0 03-28-2011 11:15 AM
Townhouse basement insulation benb Building & Construction 0 02-15-2011 10:32 AM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Basement Insulation raulakh Building & Construction 2 10-13-2009 01:36 AM
