Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-20-2012, 10:01 PM   #1
Basement framing- need help
Is it ok to use a metal as a base and wood for studs. I want it to be to code for nj. Please someone , help
Pvtces is offline   Reply With Quote
Old 02-20-2012, 10:30 PM   #2
Metal? What's wrong with pressure treated wood? Call and ask your local building inspector.
B
Beepster is offline   Reply With Quote
Old 02-20-2012, 10:46 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
are you talking about using steel stud track for your plate? if thats the case no.. the studs wont stay in place. dont mix and match framing material
woodworkbykirk is offline   Reply With Quote
Old 02-21-2012, 07:29 AM   #4
Disabled wood vet
titanoman's Avatar
Why metal plates? There's no code calling for that.
titanoman is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Insulate split framed/poured basement wall, prior to framing... pasichnyk Building & Construction 9 12-20-2010 06:32 PM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 01:06 AM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
