Basement Framing Around Pipes - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 03:11 PM   #1
Need some help on how to work around a plumbing pipe that is right next to the wall so I can not get the top plate attached to the joist. The only option I cam up with is to build the wall under pipe and use blocking in between the studs that will be attached to the concrete wall. Just need to know what will be the safest and easy way to handle this.
buildit45 is offline   Reply With Quote
Old 03-06-2012, 05:43 PM   #2
Rewards Points: 2,212
Looks good! Of course I assume you'l do a treated bottom plate.
Also for insulating behind iit do a search on the forum.
mae-ling is offline   Reply With Quote
Old 03-09-2012, 10:49 AM   #3
I would think about some sort of soffit around that area. You want attachable structure for every corner for drywall. If your doing a drop ceiling then this might be ok.
bkeech is offline   Reply With Quote
Old 03-09-2012, 11:19 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
Does that wall attach to the one at the stairs? If so I think you'll be fine. Only looks to be about 6'. Maybe double top plate to stiffen it up a bit. If it makes you feel better a couple of blocks wouldnt hurt.
And as cliffs' cat said, dont forget insulation back there.
12penny is offline   Reply With Quote
Old 03-09-2012, 11:24 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Install a horizontal 2x6 PT wood cleat on the masonry wall (Use PT since its masonry, and I am suggesting a 2x6 over a 2x4 to minimize wood splitting and wood blow-outs). I suggest using tapcons to secure.
Construct a soffit around the duct work and tie it into the cleat (bottom edge). Then build your wall and attach the wall's top plate to the soffit's underside framing.
Use ridgid foam board insulation (for the wall) against the masonry areas (not fiberglass).
- Build Well -
Tags
basement framing
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Best way To frame basement ceiling under pipes rhk119 Remodeling 5 02-14-2012 05:22 PM
basement framing and insulating questions around ledge khatz Building & Construction 8 01-02-2012 12:50 PM
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 12:06 AM
