Basement Finishing Walls Or Floor Which Is First? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 02:17 PM   #1
Basement finishing Walls or floor which is first?
Hello I am looking to finish remoddle my basement. I don't know whether to start with the subfloor or put up drywall. Both the walls and the floor are concrete.
Annetitch is offline   Reply With Quote
Old 11-16-2011, 03:33 PM   #2
Rewards Points: 5,336
Why do you need a subfloor in the basement?
What were you planning for the floor(finished and subfloor).
Ron
B. Franklin 1759
Old 11-20-2011, 06:43 PM   #3
Annetitch, it can be done either way. Mostly, you will want to do which ever is easier, and there are advantages to both ways. If you finish your walls first, you can put in a floor then baseboard and not have to protect your new floor from damage during construction. If you finish the floors first, you will have to protect them with plastic or rosin paper, but you can then do some very interesting details for where the drywall meets your flooring and possibly eliminate baseboard all together.
Your first step would be to pick out finishes (mostly, what type of floor do you want to put in), and generally how you want it to look like in the end, and that should prescribe an order of operations.
mdj180 is offline   Reply With Quote
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 03:42 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 07:54 AM
