Basement Finishing - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-06-2009, 07:29 AM   #1
Basement finishing
Hello,
I am finishing my basement, and I was hoping that someone can give me some material estimates based on this drawing... Or an accurate calculator.
Ceiling is around 7' 5"
Right now just wanting stud and drywall (4x8) quantities...
Some walls are already framed and finished. The staircase and the wall directly at the end of the stairs...
Here is the bathroom so far...
ORion is offline   Reply With Quote
Old 05-06-2009, 11:23 AM   #2
One rule of thumb for framing is 1 2x4 for every foot of wall. You will have to add plate stock to that figure. There are to many dimensions missing from your drawing to even come close. YOU will need to take the time to fill in the missing and add up the footage.
Mop in Hand is offline   Reply With Quote
Old 05-06-2009, 11:33 AM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
I hate mentioning this, but I operate a construction estimating service. If you want, I can take a look for you. E-mail me at estimating@oakridge-engineering.com.
Aggie67 is offline   Reply With Quote
Old 05-06-2009, 11:53 AM   #4
Registered User
Rewards Points: 526
If you don't know how to estimate the material that you will put in, how will you know where to put the material? Not just studs, there is fire blocking, draft stopping, fixture backing, rod backing, headers, trimmers, casing backing (for wide trim), wallboard backing, and more.
I suggest you get a permit from your local Building Department. You forgot your bedroom windows, and basement egress.
Your first question should be: How do I cut my brick wall for bedroom windows?
Your bath ceiling needs fire stopping. Please get a permit. Be safe, G
Old 05-06-2009, 01:30 PM   #5
I did not forget egress... the basement is a walkout and the basement is exposed on the west side....I already have someone in line to add the windows... they are not in my rough drawing... Just wanted to get some opionions....
Old 05-06-2009, 03:25 PM   #6
Aggie67's Avatar
Rewards Points: 826
Orion, I sent you the take off.
Old 05-08-2009, 05:07 AM   #7
Thanks I got it and replied!
Finishing basement, had a few questions about ductwork... Wyjeep Plumbing 12 04-27-2010 09:27 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
Finishing basement - low ceilings alyuka Remodeling 1 01-05-2009 08:13 PM
Finishing old basement force4ormore Building & Construction 1 12-29-2008 02:48 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 08:28 AM
