Basement Finishing - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-24-2007, 09:26 AM   #1
Basement finishing
I believe I'm getting the go-ahead from my wife to start finishing the basement. The area I'm going to finish is about 15x30. The whole basement has a trench drain around the perimeter and we only had water once, but I think it was from the crappy jelouis(sp?) window.
So with this trench I'm going to have to keep off the wall
Do I have to seal the block wall before I start?
When attaching furing strips it is better to use glue or one of those nailers?
Is there any good articles or faq's about DIY basement finising?
Also on the flooring aspect of it, if I do a pergo or laminate flooring, what should I use to cover the floor in case of water?
Any other suggestions would be sweet
BTW in one of the walls' i plan on putting in a wall of fish tanks w. the filters and stuff hidden into my work shop
TIA-chris
smallcrpt is offline   Reply With Quote
Old 10-24-2007, 10:07 PM   #2
timthetoolman
If you have noticed water before, i think your best bet would be to seal the walls prior finishing them. If it were my house i would, this small effort and cost could save ya headaches in the long run.
If you are putting up paneling on the walls, glue on furring strips would probably be sufficient. If you are using drywall, i would definately rent a 22 nail gun and nail the furring strips to support the weight.
When i finish basements i usually recommend using green board (weather resistant drywall, which goes up the same) on the lower half of the walls. It comes as very little extra cost, and again if you ever have water problems, you don't also have problems with the paper peeling off the drywall!!!
timthetoolman is offline   Reply With Quote
Old 10-25-2007, 05:45 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you had a french drain installed, it should do it's job. If it includes a pump, keep it serviced and checked periodically.
Block walls tend to absorb a high level of moisture. I would suggest sealing the wall.
If you can get away with creating new walls that are actually in-front-of your masonry walls, leaving 1" -2" of space, you will create an area to allow moist air to flow and not be trapped - I always suggest this when possible.
If you feel that you must have that extra space, and need to attach furring strips onto the masonry walls: you have a few options. I would suggest that you use a construction adhesive with all your options. You could use tapcon masonry screws or a .22 caliber powder actuated fastener with washered fasteners.
Yes, there are many available online:
http://www.doityourself.com/scat/basementremodeling
http://www.rd.com/content/openConten...ontentId=17480
http://homeenvy.com/db/3/163.html
... or in instructional-picture-book format:
http://www.amazon.com/Complete-Idiot...245225-6412114
http://www.basements101.com/training.html
I would suggest you:
a.) Consider another choice of flooring material, if you have a high level of moisture present in your basement, or if you feel that your past moisture issues have not been fully corrected.
b.) All laminate flooring manufactures state that it is best to use a moisture meter to test your sublayer/substrate (concrete floor) prior to installing any laminate flooring products. There is a minimum % of moisture that should not be acceded.
EXAMPLE from Pergo Installation Instructions:
"MOISTURE TEST:
A moisture test is recommended on all concrete
subfloors and wood subfloors constructed over a
crawl space or basement. Maximum acceptable
moisture reading for wood subfloors is 14%. Maximum
acceptable moisture reading for concrete subfloors
is 4.5% or a moisture vapor emission rate of 5lbs/1000sq. ft/24 hrs." - - From http://www.pergo.com/images/pdfs/Install_Essentials.pdf
c.) What should you use under your Laminate Flooring (Between the concrete and the Floor itself)? Answer:
"If the laminate flooring is going to be installed on a concrete slab floor where there is earth below the concrete, a vapor barrier must be placed between the concrete and the laminate. The seams should be taped with a moisture resistant tape. Laminate flooring should not be installed on any floor that has a drain." - From: http://ezinearticles.com/?Installing...nts!&id=307282
Also - Read up on the basics of Installing Laminate Flooring:
http://www2.dupont.com/Laminate_Floo...tallation.html
Good Luck.
- Build Well -
Old 10-25-2007, 06:28 AM   #4
Originally Posted by timthetoolman View Post
...When i finish basements i usually recommend using green board (weather resistant drywall, which goes up the same) on the lower half of the walls. It comes as very little extra cost, and again if you ever have water problems, you don't also have problems with the paper peeling off the drywall!!!
I am sorry Tim, IMHO - I would have to disagree with recommending Moisture Resistant sheetrock (A.K.A - M.R. Board/ Green Board)...simply because there are far superior products available on the market now.
Green Board first came out in the 60's. We used it alot in the 80's and 90's in bathrooms. Essentially, it is a wax-coated sheetrock, that contains a gypsum core that claims to be "treated" with a moisture resistant compound. The product was originally designed to be used in commercial environments with high amounts of "moist air"....but not moist environments or environments that can/may potentially get wet.
- There are bathrooms all over the US that have crumbling walls. We just repaired 6 shower walls at one apt. complex due to rotted green board. When green board gets wet, it will rot just like standard sheetrock.
In all the basements that we repair or remodel, we install Pressure Treated Lumber wall plates. Ridgid foam board insulation on the bottom 12" of all wall cavities/or all wall cavities. Last, we prefer to install "Densarmor" on the lower portion of the walls and "XP" board on all other upper areas/or Densarmor everywhere.
Consider using these new products that are rated as "Mold and Mildew" resistant (densarmor and/or XP-board):
http://www.nationalgypsum.com/products/product69.aspx
http://www.gp.com/build/product.aspx?pid=4659
Whether you have high levels of moisture in your basement or not, all it takes is a burst plumbing line, sudden minor flood, backed up ejection or sump pump, failed hot water storage tank/valve/line, etc....and you will have sudden water in your basement. You will be glad that you finished it with high-rated moisture and mold resistant materials.
There are now some towns, where the inspectors are suggesting that this be done for a basement repair issue (we ran into this in Wilmington, MA last year). Many Insurance companies are detailing that similar guidelines be followed for basement repairs as well (Job we did in Westford, MA last year).
- Build Well -
Old 11-01-2007, 06:13 PM   #5
Don't use a 22 cal. ramset on block walls....They do not always hold and they usually crack or split the firring strips. I always drill and screw concrete screws
localtradesman is offline   Reply With Quote
Old 11-01-2007, 07:21 PM   #6
Absolutely....a drop of epoxy or Heavy duty construction adhesive on the screw is also a good anchoring measure...
- Build Well -
Old 11-04-2007, 12:33 AM   #7
timthetoolman
thanks for the advice there atlantic. No seriously, i guess i kinda misconstrued that info in my head there. So really greenboard has no advantages in basements? Garages? I will check into using these other materials! Thanks again!
Old 11-04-2007, 08:20 AM   #8
ok
i just talked to a guy who finished his basement w/ the 22 cal hammer. But I dont think drilling into the wall and furring strip is that big a deal. How many screws / strip would suffice?
Also what insulation is the best? the pink foam?
He also said he drywalled the ceiling, but I'm still thinking a drop ceiling just because most of my electrical and plumbin for the rest of the house is in there, so if i have remodeling or anyting i dont wanna have more work than i already have.
-chris
Old 11-05-2007, 12:58 PM   #9
AtlanticWBConst:
I am also starting a basement remodel.
What is the cost differential between the XP and/or Densarmor and regular drywall?
Also, is it recommended to keep the board off of the concrete floor when installing?
My basement is already studded out but it is currently paneled, which I am going to replace. I have yet to take the paneling out to see if there is any insulation behind it. What is the purpose of the rigid foam insulation?
Thanks.
simon is offline   Reply With Quote
Old 11-05-2007, 03:37 PM   #10
Tagging along! Starting my own basement remodel soon.
perpetual98 is offline   Reply With Quote
Old 11-05-2007, 06:40 PM   #11
Originally Posted by simon View Post
AtlanticWBConst:
Thanks.
Last time I checked the Densarmor wasn't much more than regular sheetrock, the downside is that because it is a "Paperless Sheetrock", it is held together by fine thread of meshed fiberglass threads and required skim-coating the surface with compound. This is actually not that big of a deal, even for the DIYer. I think the pricing was around $3.00 more per 8 foot sheet. That was about 6 months ago.
XP board was ranging about $5.00 more per 12 foot sheet over standard sheetrock. Again, please check the current pricing for yourself.
Simply make some calls to your local suppliers or stop by your local Home Improvement store and compare. I believe that both products are now being carried by the major retailers now.
- Build Well -
Old 11-05-2007, 06:41 PM   #12
Good Luck, Hope there is alot of helpful and motivational information here for you.
- Build Well -
Old 11-06-2007, 05:34 AM   #13
xp board
do you have to also skim coat the xp board? i'm starting to get excited about the basement, just need to finish the kitchen painting, get the hot tub up and running, rake leaves, fix outdoor lights, clean fish tanks, ... .. ... .. and so on..
but those aren't to big a deal
=-thanks a lot so far..
-chris
Old 11-06-2007, 04:52 PM   #14
do you have to also skim coat the xp board? ....-chris
Coating is the same as standard sheetrock coating.
Good Luck.
- Build Well -
Old 11-07-2007, 02:43 PM   #15
Seasoned Noob
Rewards Points: 95
i completed my basement remodel about aa year ago... I used standard drywall but only have it on one block wall. I've never had water and should never have water an due to the builder putting stairs on the front, furnace in teh middle, sump in one corner, and water line in the other corner, i had to be creative and make "walking spaces" between the block walls and drywall walls. The walk space where the sump is became a nice pantry
Only thing I can say abotu a basement remodel is 'be creative'. there are tons of things to build around, incorporate, etc. Just be creative in how you handle them.
hubbard53 is offline   Reply With Quote
Finishing part of a basement hexydes Remodeling 5 10-09-2007 01:48 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 08:28 AM
A newbie basement finishing project DIY4EVER Building & Construction 6 05-11-2007 09:48 AM
Finishing Basement, How to run a heat duct? hyper Remodeling 6 02-23-2007 03:46 PM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 07:48 PM
