Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-27-2005, 06:36 PM   #1
Basement Excavation
I am interested in digging the basement of my 90 year old home to get more headroom in the basement, and then finishing the basement and duplexing it to the first floor.
Does anyone have any recommendations or pitfalls to avoid when digging a basement deeper? I am planning to go 16" deeper all over. The ground the house is build on is relatively level and is some mix of sand & clay.
Does anyone have experience they'd care to share doing this in an older home? Any advice or warnings are appreciated!
Thanks.
ren2063 is offline   Reply With Quote
Old 03-10-2005, 03:56 PM   #2
Basement Excavation
you can not excavate below existing foundations. if your floor level is lower you will
revert to underpining the walls. is expensive to intall and you have to no what you
. doing. if you do it and need a dry room get it tank in ashplete you can put the Mrs
in there all the best jonneybbob
jonneybbob is offline   Reply With Quote
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 09:28 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
