Basement Dryout/remodel - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 03:53 PM   #1
Basement dryout/remodel
Hello all, I've been doing a lot of searching and I think I have finally found 1) a great forum and 2) an answer to my problems. Of course, the answers leads to more questions!
Let me try to be short with the background. I'm in the beginning stages of getting my basement ready to be finished. The first thing that needs to be dealt with is the mildew/mold problem. The basement is block wall, with an interior french drain system (that works) and the concrete slab is an inch or two away from the wall. I have a sump hole/pump that collects the water and sends it out doors. During Hurricane Irene where we saw massive amounts of rain fall, my basement did not flood. I get no water leakage through the walls, I have a few spots with efflorescence, and a few more where the block is wet (my guess is water is inside the block and slowly drying out). All in all, the basement is fairly dry, but the humidity level is what is very high - hence the mold/mildew.
I'm thinking that some type of foam panel is my best bet to get rid of the moisture/mildew problem. But considering that my slab does not touch the wall, do I put up the panel so it covers the trough? Or should I set them so they sit just above the trough?
Thank you in advance.
Oldmanskater is offline   Reply With Quote
Old 11-02-2011, 12:36 AM   #2
Registered User
Rewards Points: 5,216
Page 14: http://www.buildingscience.com/docum...lation-systems
Gary
Old 11-02-2011, 10:21 AM   #3
Awesome...thanks for that!
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 01:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
