Basement Ceilings Ideas Needed - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 08:59 PM   #1
basement ceilings Ideas Needed
what are some ideas for a basement ceiling under a manufactured home? there are steel beams and plumbing to work around. We are not interested in a drop style ceiling.
Kmikrot is offline   Reply With Quote
Old 09-29-2012, 09:03 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Wood framing to box all beams and pipes. Then drywall.
You ought to reconsider a suspended ceiling.
Coastal South Carolina
Old 09-29-2012, 09:11 PM   #3
are suspended ceilings a good type of insulation?
Old 09-29-2012, 09:25 PM   #4
I agree you should re-consider doing a drop down ceiling if the height of your basement permits, check your local code to find out what your minimum height from finished floor to ceiling is. acoustical ceilings give you a finished look and ease of access to pipping and electrical work.
FixItSteve is offline   Reply With Quote
The Following User Says Thank You to FixItSteve For This Useful Post:
Kmikrot (09-29-2012)
Old 09-29-2012, 09:49 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
a dropped ceiling makes the most sense for a basement ceiling because as mentioned you have easy access to your mechanical systems and a finished ceiling. check with your building department for any code requirements for clear height from finish floor to finish ceiling in a basement.
check out this link and google as well http://www.armstrong.com/resclgam/na.../us/panels.asp
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-30-2012, 08:38 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
Another way that I have done is to use the gridwork for a drop ceiling but hang drywall to the gridwork instead of dropping in acoustical ceiling tiles. This requires lots of grid wire to hang the grid from and to hold the weight of the drywall. Using the grid you end up with really nice straight framing that can cover a long span(with correct tie wire of course) and the width of the framing material is not thick at all when compared to using a 2x6 or 2x8...
hand drive is offline   Reply With Quote
Old 09-30-2012, 09:56 AM   #7
Thread killer
Rewards Points: 272
There are options if you don't want to lose ceiling height
http://www.ceilinglink.com/
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 10-01-2012, 09:45 AM   #8
Amateuralex's Avatar
Rewards Points: 270
We have a fairly standard basement ceiling with joists, ducts etc, 8 ft to the joists, and we tidied up the electric, installed pot lights all over, and had the entire thing painted flat black. We love it. Way more headroom. Looks great. We despise the look of a suspended ceiling. And the ceiling tiles that don't look like the cubical farm that I work in are very expensive.
Painting it black looks industrial and modern. It wasn't oppressively dark or anything. The ceiling lighting is important. And we still have easy access to the ducts and pipes etc for maintenance. And if we decide to frame or suspend it later we can with ease.
Amateuralex is offline   Reply With Quote
The Following User Says Thank You to Amateuralex For This Useful Post:
rjniles (10-01-2012)
Tags
basement , ceiling , manufactured home
finishing a basement - advice needed joe99 Remodeling 17 09-12-2012 09:15 PM
Basement Room Ideas fax6202 Project Showcase 6 05-05-2012 03:20 AM
Ideas needed for placement of Stereo Speakers on outside deck/patio mafmmx General DIY Discussions 5 04-07-2012 12:04 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
