Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-02-2009, 01:25 PM   #1
Default Basement ceiling question
I am finishing an unfinished room in my basement putting up drywall and it is time to cover the ceiling. Since it is a basement I have decided to install drop ceiling. I have decided on the ceiling height, however I do have a question. Can someone tell me what the two 2x4's coming down from the ceiling are? They are attached to the joists with small metal strips. For the life of me I can't figure out what their purpose is. The only thing I can come up with is that they may have something to do with the fact that on the exact same spot upstairs is the landing area from the steps. Can anyone shed some light? Is it ok to cut 5" off of the bottom of these?
Here is a photo.
Thanks in advance
Ari
aggst1 is offline   Reply With Quote
Old 11-02-2009, 01:40 PM   #2
Not so new
12penny's Avatar
aggst1....An answer requires a photo of the offending 2x4's.
A correct answer requires you finish your profile.
12penny is offline   Reply With Quote
Old 11-02-2009, 01:40 PM   #3
Probably the ends of the framing for the newel post, brought through the floor to give stability and strength.
http://www.rd.com/57548/article57548.html
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 11-02-2009, 01:48 PM   #4
My apologies for the delay. I have now posted a photo. I will be finishing my profile in a couple of minutes. Thanks for the quick responses
Old 11-02-2009, 01:53 PM   #5
Just to clarify, the posts do not appear to extend through the subfloor of the upstairs.
Old 11-02-2009, 01:56 PM   #6
Not so new
12penny's Avatar
aggst1...I have no idea.
Old 11-02-2009, 05:19 PM   #7
Anyone have an idea?
Here is another photo from a different angle
Old 11-02-2009, 07:31 PM   #8
If they don't go through the floor, they are from the electrician holding up his wire spool for ease of pulling wire rotating on a pipe. Newer ones have a swivel and just hang from a joist.
Cut them off.
Be safe, Gary
Old 11-02-2009, 08:39 PM   #9
Home Slave
Lazy_Jake's Avatar
Yeah! Get rid of that stuff. Drop that ceiling!
Lazy_Jake is offline   Reply With Quote
More On This Topic
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Hi I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. After your drywall has been taped and textured it's ready to cover up with paint, which is the next step. Painting is another job that a lot of homeowners... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
The Sign Aries in Astrology
The Sign Aries in Astrology by Expert Village
Hi. On behalf of Expert Village, I'm Gnobo A. Calypso, also known as Bryce. And, I'm here to tell you about astrology. Okay. Now's the fun part. We're going to discuss some characteristics and traits of the twelve astrological signs. The first one that... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
finishing basement question fabian Building & Construction 6 06-19-2009 01:59 PM
HELP! lighting question for vaulted ceiling pauls General Discussion 2 12-12-2008 09:25 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 11:10 AM
basement ceiling joists-how to know if they are level? yummy mummy Building & Construction 22 02-06-2007 10:16 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 10:27 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
