Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-03-2009, 12:26 PM   #1
Basement Ceiling
Hey Everyone,
I have just started my basement project and I'm having trouble figuring out how to frame a hallway ceiling. I have HVAC, Plumbing, Electrical and more that is preventing access to the floor joists, so I'm not sure what to screw into.
I will try to post pics.
stewiedogg is offline   Reply With Quote
Old 06-04-2009, 07:31 AM   #2
Basement Ceiling
Sounds like you will need to add furring as nailers, but keep in mind that the things you mention need to be protected from nails/screws with metal plates.
Old 06-04-2009, 10:32 AM   #3
Basement Ceiling
So I put in furring strips 2x2 with a top and bottom plate. Then create a frame for the ceiling?
Old 06-04-2009, 12:49 PM   #4
Basement Ceiling
You can either "hang" the ceiling framing from the joists above by dropping down 1x4 or 2x4 "legs" where you have access to the joists or you can place new "ceiling joists" across supported by the adjacent walls. Depending on the width of the hallway the new ceiling joists could be 2x4s or maybe even less.
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
How do I drop a basement ceiling 1-ft? ThunderCAT Building & Construction 2 02-02-2009 08:47 PM
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 08:24 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
