Basement Bathroom Input - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 11:26 PM   #1
Newbie Bill
Rewards Points: 518
Basement bathroom input
Hey everyone, we are in the planning stages of finishing our basement and would like input from everyone.
The location we want to put the shower only has a ceiling height of 6 ft, 9 inches tall. So After shower base, tile, ceiling, we will only have about 6 and a half feet in there. That is plenty of room for short guys like me, but anyone over 6 feet tall could find the ceiling height an issue. The shower will likely be 3ft X 5ft, so that is a good size, the height is my only concern.
Is this height going to be a problem?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 07-22-2013, 12:56 PM   #2
Newbie Bill
Rewards Points: 518
Does anybody have any feedback? Good or othewise?
Bill
Old 07-22-2013, 02:43 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
check with your building department in regards to finished height. some codes have a minimum requirement for height of 7' and at least 6'-8" in front of plumbing fixtures. your building department can let you know what your requirements are if any.
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-22-2013, 03:53 PM   #4
Newbie Bill
Rewards Points: 518
Will do Gary.
Any thoughts from just a plain functional standpoint?
Bill
Old 07-22-2013, 04:05 PM   #5
Rewards Points: 660
Are you measuring this height to the bottom of the joists, or are you under some obstruction (HVAC, pipes, etc.)?
B
Beepster is offline   Reply With Quote
Old 07-22-2013, 05:48 PM   #6
Newbie Bill
Rewards Points: 518
Hey Beepster, I measured from the bottom of joists to the concrete floor. No other obstructions.
I just talked to local inspector. He said there isn't any issue if it is just a bathroom with a ceiling that low. Now if the entire basement was going to be at that height, we would have a problem.
So we are OK from a code standpoint. Any thoughts? Don't be shy.
Bill
Old 07-22-2013, 06:59 PM   #7
DIY staff
Rewards Points: 7,174
Consider removing the concrete from the shower area and building a barrier free shower---with this you will not be adding any height from a pan---
3x5 is a nice sized shower---I would likely shrink the door opening down to 4 feet so a standard door could be used---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
drtbk4ever (07-23-2013), gregzoll (07-22-2013)
Old 07-24-2013, 03:01 PM   #8
Newbie Bill
Rewards Points: 518
Good idea on the barrier free shower Mike. We have to move the plumbing anyway so some of the concrete is being removed anyway. I'll talk to the plumber on that.
OK, next issue. Since the ceiling is going to be quite low it is going to get wet. I doubt regular paint and drywall would last too long in that environment.
Any suggestions on what we can put on the ceiling above the shower that can handle that?
Bill
Old 07-24-2013, 08:19 PM   #9
DIY staff
Tile it---I like the look and you will never be concerned with it deteriorating--
It's not hard to do---
basement bathroom breiding200 Plumbing 4 03-22-2011 11:40 PM
basement bathroom breiding200 Plumbing 2 03-15-2011 04:05 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 11:08 AM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 05:27 PM
