Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-01-2007, 12:26 PM   #1
Unhappy
Basemant Moisture on flooring
We found our 20 year old home w/ finished basement had some minor mold issues. We removed the old drywall from the outer cinder block wall and sealed the cinder block and floor with drylock. Insulated walls with rigid foam sealed and vapor barrier. Placed with Mold resistant drywal, trated furring and vinyl flooring.
No we are getting moisture on top of the vinyl. We live in Fairbanks Alaska and it is cold. Heating is forced air and the water is showing up in one room in the corner of the house basement on the floor.
Is this a humidity issue from condensation? Should I redo the heating system and place radiant floor heating with an HRV or should I do a subfloor?
Steve
Dannun66 is offline   Reply With Quote
Old 12-01-2007, 03:07 PM   #2
Home Improvement Guy
ron schenker's Avatar
Why don't you just put in a dehumidifier?
ron schenker is offline   Reply With Quote
Old 12-01-2007, 08:16 PM   #3
Well I needed to solve the mold issue. Since my post I have done further research and discovered I created another bad environment for more water to shed off the cold cinder blocks onto the floor.
It needs to be fixed now or it will eventually mold and water will continue to form in the cavity between my rigid foam, and my second vapor barrier and literally drain onto the floor.
I wish I could solve it with just a humidifier but I think there is way to much water shedding from behind the wall.
Thanks for advice
Old 12-01-2007, 09:14 PM   #4
s0lidgr0und's Avatar
You'll never solve a mold problem in a basement with that heavy of a water infiltration, especially if you keep giving the mold a food source. (The drywall, etc.)
s0lidgr0und is offline   Reply With Quote
Old 12-02-2007, 06:18 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Another possibility: Look into the chance of a draft of some-kind coming into that area of the foundation/floor.
Cold air meets hot air and you get condensation...
- Build Well -
Old 12-03-2007, 11:50 AM   #6
may be a leak is not possible in such a cold weather as everything is ice... but if this is a leak from outside wall... the only solution is to fix the leak...
KUIPORNG is offline   Reply With Quote
Moisture in Concrete LBlack Flooring 9 10-31-2008 08:24 PM
Basement finishing smallcrpt Remodeling 18 11-12-2007 06:27 AM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 10:08 AM
