Baseboard Moulding Taller Than Air Registers - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-27-2009, 04:09 PM   #1
Rewards Points: 37
Baseboard moulding taller than air registers
I'm replaceing all the baseboards in our living room and kitchen since I just installed new hardwood. We had the small 3.5" tall baseboards before and want to go back with 5 or 5.5". I'm not sure which height exactly. The problem is that the new baseboards would be taller than our heating/air condition registers that line the room. They are the kind that come up through the floor right up against the wall and the register sits on the floor up against the wall and the front is angled like a triangle. The register is 4.5" tall.
Should a space for the air registers be cut out of the baseboard so it just frames them in or can you get registers that are taller?
Thoughts? I'm open to any ideas.
Thanks!
interplexr is offline   Reply With Quote
Old 03-27-2009, 05:12 PM   #2
Drywall contractor
Rewards Points: 1,070
A picture would certainly help, but if I'm seeing this correctly in my mind's eye, the supply duct comes through the wall right at or close to floor level?? I would turn the base (miter it on a 45 like a casing on a door) up and around to "picture frame" the hole for the supply and mount the grill to the actual baseboard.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-27-2009, 05:49 PM   #3
Rewards Points: 37
Here is a picture of the register installed w/o baseboards.
Old 03-27-2009, 06:01 PM   #4
Drywall contractor
Got it! The same thing will still work, your "picture frame" will just be around the outside of the register. The board that runs to the register (from the left in your picture) would have the "long point" of a 45 degree angle touching it. The piece running up the left side would have the "short point of a 45 at the top of the register. "Short to short" across the top, etc....
Old 03-27-2009, 10:20 PM   #5
I think bjbatlanta is on the right track, another way would be to case frame around it (as in door casing) only thicker than the base moulding.
Mop in Hand is offline   Reply With Quote
Old 03-31-2009, 10:27 AM   #6
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
I too am trying to picture this in my mind... Am I not seeing something or will framing it with 45s not work if the molding is bigger than the register... in other words, 45 degree angles will only box around something at least as tall as each molding piece, right? The origin of the angle on the horizontal side to the floor will be higher than the object its framing...
J187 is offline   Reply With Quote
Old 04-02-2009, 02:22 PM   #7
Rewards Points: 22
I just cut out the section of baseboard. Also purchased wood vents and finished them to match the baseboard.
dkh0331 is offline   Reply With Quote
Old 04-02-2009, 08:03 PM   #8
Looks great, nothing wrong with that either.
Old 04-03-2009, 06:24 AM   #9
Drywall contractor
Looks good to me!
Tags
baseboard , hardwood , moulding , register , trim
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 10:52 PM
Moulding options for badly warped wall? marc205 Flooring 4 01-21-2008 07:43 AM
baseboard registers hertel1 HVAC 1 10-18-2004 01:53 PM
What paint for baseboard registers? Unregistered Painting 1 02-05-2004 08:17 AM
