Baseboard Heaters Under A Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 01:33 PM   #1
Baseboard heaters under a window
Do baseboard heaters have to go under a window?
mturner is offline   Reply With Quote
Old 01-16-2012, 02:11 PM   #2
Rewards Points: 13,712
Only if you want them to do any good.
All heating vents need to go under or at least as close as possible to all windows and door opening.
You have cold air coming in and falling, the heater preheats that air and convects warm air up into the room.
Old 01-16-2012, 03:07 PM   #3
Rewards Points: 2,212
Why would you not want it under the window? Will it not fit for some reason?
Then can go any place but as stated are best under a window.
They also make ones that are more square and have built in fans.
mae-ling is offline   Reply With Quote
electric baseboard heaters garyjackel1 Electrical 17 12-23-2011 05:49 PM
Baseboard heaters on one thermostat shadesofblonde Electrical 10 10-12-2011 12:43 PM
Different Load Baseboard Heaters in Parallel pankaek Electrical 4 03-25-2011 02:52 PM
Electric baseboard heaters ? ants1929 HVAC 11 03-11-2011 08:23 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
