Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-01-2010, 10:24 PM   #1
baseboard heat cover
I recently removed some wood paneling from a bedroom in my home. When the paneling was installed it was installed before the baseboard heat was installed. My question is how can I remove the paneling from behind the baseboard heat cover? I have been able to remove the nails from the baseboard heat cover but the paneling is still not sliding out from behind it....it seems as if the paneling was nailed in right at the base near the floorboards and I have no way of completely removing the covers to access those nails. If I leave the paneling in there just behind the the covr than what is a good way of covering the 1/4 inch gap between the baseboard heat and the wall?
SteveBman is offline   Reply With Quote
Old 02-01-2010, 10:32 PM   #2
jlhaslip's Avatar
aren't there screws you need to remove so as to move the baseboard?
got a picture?
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-02-2010, 08:00 AM   #3
gravity always wins
I am assuming this is hot water baseboard heat. Trim off the panelling at the top of the baseboard shell with a utility knife. Then add a moulding, cove or quarter round to cover the top edge. It's a pain to try and unhook all of the fin tube brackets and then work the shell out from behind. Putting it back in again is just as bad. Plus, if you do get it out and then get it reinstalled, the shell will set back the thickness of the panelling closer to the wall. That means you have to watch whether your fin tube can move back that distance as well. Otherwise it may not hang in the brackets correctly.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 8 11-19-2011 11:45 PM
gurgling in baseboard heat in_the_basement HVAC 1 11-06-2009 11:41 PM
Need to paint metal baseboard heat covers bug Painting 5 02-11-2009 10:53 AM
baseboard heat covers rich daly General Discussion 1 08-25-2006 03:08 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
