-   -   Badly Installed aluminum double hung windows in a rental (http://www.diychatroom.com/f15/badly-installed-aluminum-double-hung-windows-rental-35246/)
Mrnagrom 01-06-2009 11:45 AM
ok so i live in a loft in nyc (noisy) and my main room (the largest) has 7 large aluminum double hung windows. I feel the windows were badly installed because they have a bit too much airspace between the sash and the windows so it's basically like leaving the window open and it lets the noise in.. is there anything i can do? right now there's wool pile in a track around the window but it doesn't even touch the sash. I haven't even been able to find a thicker wool pile that fits in the track size i have.. i was looking at bubble seal but i don't know if i could use that, it seems like it would make a better seal and i guess i could put some lubricant on the sash so the rubber bubble would still slide.
i'm just sick of these windows the way they are.
thanks in advanced.
Tom Struble 01-06-2009 01:03 PM
how old are the existing units?
Mrnagrom 01-06-2009 01:59 PM
judging from that tag thats still on them.. probably about 2 years
Tom Struble 01-07-2009 01:31 AM
if your windows tilt in do so and see if you can see a screw or a hole with a screw in it and try to tighten it most replacement type windows have a shim wedge built in to the side rails if not you might have to remove the trim and shim them straight with wood shims
