Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-10-2008, 07:28 PM   #1
banging thumbs
Backsplash tile - spacing electric boxes
I'm moving on to the rewiring of the kitchen and I have a question about positioning the depth of the electrical boxes before I finish and drywall (1/2") over. My electric book says to extend the box face 7/8" from the stud for ceramic tile, 3/8 further than the drywall thickness. Does this sound correct?
I'm just getting to my backsplash/tiling education. Should I be applying the tiles directly to the drywall?
As usual, thanks.
bakerhouse is offline   Reply With Quote
Old 05-10-2008, 08:11 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
I use standard 1/2" plaster rings and then just use longer 6-32 screws when you're installing the outlets. If you really want you could use 5/8" plaster rings but it's not necessary. When you tile, you need to make sure you're close enough when cutting around the openings so the ears on the outlets will sit on the tile. Once you do one, you'll get the hang of it. I'd suggest to have an outlet handy (NOT hooked up to the AC yet) and place it in your opening while tiling to make sure you have proper clearances. Also, if you have a GFI style outlet, you'll need to make sure the screws for the cover can recess deep enough behind the tile. See picture. See how the screw hole for the toggle switch is within the opening but the screw hole for the GFI cover is way at the end? So if the ears of the GFI are OVER the tile and you try to screw the cover on, the screw cannot go into the tile so you won't be able to get the screw all the way in. You need to make a small notch on the tile so the screw can be pulled in past the face of the tile. You have to be careful you don't make the notch so big that the cover can't hide it. Like I said, lay the stuff out BEFORE hand so you fully understand what I mean. If you don't and and fail to make that notch, you won't be able to completely screw the cover on and it will look like pooh.
As for the tile, yes you can go directly over the drywall. I use a modified thinset like Ultraflex II. Make sure your first row up from the counter is level. If the counters aren't level, keep the uneven line between the counter and the bottom of the tile. You'll caulk that line anyway. Also use caulk if you have a 90° corner. Some will say you can use mastic for the tile. You can but I'm not a fan of it. I spend the extra few minutes to just mix some thinset and it's all good. Mastic and water don't mix so even though a back splash is technically not a wet location, I play it on the safe side.
Good luck. Take and post pics for us!
angus242 is offline   Reply With Quote
Old 05-10-2008, 08:12 PM   #3
angus242's Avatar
I'm actually doing a tile back splash next week. I'll post actual pictures as I go along.
Old 05-10-2008, 11:46 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
The best thing to do, is get the boxes that are adjustable. They work great in situations where you do not know how deep they will need to be, and are adjustable by a screw.
Old 05-11-2008, 04:19 PM   #5
banging thumbs
Thanks guys. I picked up a some adjustable boxes today, so all should be good. Please post your titling photos.
Old 05-12-2008, 09:40 AM   #6
Moderator
Termite's Avatar
I believe that the 2006 I-code prohibits installation of tile to sheetrock, and requires cementitious backerboard. It will work in a kitchen, but is still not as good as backerboard.
I'm on the 2003, and don't have an '06 handy...
Old 05-12-2008, 10:10 AM   #7
angus242's Avatar
There is nothing in the TCA handbook that says you cannot install wall tile over drywall. A wet location (shower) is a different story.
Old 05-15-2008, 08:25 PM   #8
angus242's Avatar
Here is (hopefully) a better picture of what I was talking about with a GFI outlet and notching the tile for the cover screw. I just started this job today.
Old 05-15-2008, 08:59 PM   #9
banging thumbs
That's great. Thanks!
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Built in microwave into tile backsplash rballard General Discussion 1 05-09-2008 09:50 PM
porcelain tile over electric radiant heat aak3 Flooring 7 01-30-2008 09:33 AM
Subway tile backsplash bigboyjoel Flooring 3 07-03-2007 12:36 PM
Ceramic Tile Backsplash Installation DK75 General Discussion 4 11-01-2006 08:56 PM
