Backing In Wall For Upper Cabinets? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 03:06 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Backing in wall for upper cabinets?
I've never noticed if this is done or not. Maybe a good idea, but is it normal practice to put backing in for upper cabinets?
Journeyman Plumber
Old 01-14-2012, 03:10 PM   #2
Old School
Willie T's Avatar
ALWAYS !!! In fact, in the old days we used to either rip the studs down 3/4" where cabinets were to go and lay in full sheets of plywood, or fill in between the studs with plywood. Not too costly back then, but it will add a few bucks to the job today.
Put backers in for everything in your bathrooms too...... and above and to the left and right of windows for curtain rod mounting.
You going to do crown? Backers all the way there too. Some quality builders even put in backers for baseboard.... but it's not all that common.
Willie T
Old 01-14-2012, 03:12 PM   #3
Doing it myself
Alan's Avatar
Thanks. I'm assuming that backing goes in both for the upper and lower portion of the cabinet.
Journeyman Plumber
Old 01-14-2012, 03:27 PM   #4
Old School
Willie T's Avatar
Yes, because you never know where the studs will hit on odd sized cabinets. And don't forget to take into consideratin the shorter cabinets.
Willie T
Old 01-14-2012, 04:04 PM   #5
MarginallyQualified
Rewards Points: 2,464
French Cleat is perfect for most.
One item in 20 may need more.
Old 01-14-2012, 04:12 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
Amen, dead on, most carpenters won't do it that way though, and there are many who don't get enough pay to do that on market houses. That was always just the norm on my houses. People who are looking for a contractor and see a house built like that will get the job.
I am not much on French Cleats unless it is a commercial job.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
What color to paint kitchen cabinets and wall tswilbert Interior Decorating 5 09-20-2010 06:33 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Building a wall for cabinets bluefitness Building & Construction 3 01-30-2010 07:52 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
