Backerboard - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-06-2007, 09:07 PM   #1
backerboard
hello,can some body help.im installing backer board around my new tub.the tile is not going all the way to the ceiling so im going to have to texture around the tile.somebody told me i could use thin set to seal all the seams.i know i need it were the tile is going to go but after i put it on the sheet rock im going to texture it is vert uneven and it does not sand smooth.can i put joint compound over the thin set to smooth it out or can i finish around the edges were no tile will be with joint compound over the backerboard?
glassman is offline   Reply With Quote
Old 02-06-2007, 09:36 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, you can. Tho I would suggest using durabond (quick dry mix)
- Build Well -
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Backerboard not in mortar -- How bad is that? House_Amuck Flooring 28 09-27-2010 11:33 PM
Concrete backerboard vs. Greenboard amakarevic Building & Construction 1 05-22-2007 06:54 AM
backerboard glassman General DIY Discussions 1 02-11-2007 10:33 AM
What Comes First-Drywall or Backerboard?? allen1466 Remodeling 15 04-01-2006 10:57 AM
