Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-01-2010, 10:25 AM   #1
Back Splash Tile Over Old Sheet Rock?
Happy New Year DIY Family,
I'm remodeling our 1955 cape's kitchen. We just had granite counter tops installed and I am going to install a tile back splash(for the first time in my diy career)with 3/4-1" sheet tiles. Previously there was a thin sheet 1/8" of laminate covering the sheet rock attached by glue as the back splash. When I removed the laminate it began to pull the first layer of paper off the sheet rock.
My question is: do I tile directly over the old sheet rock?
or do I put up a thin peice of ply wood over the sheet rock and then adhere the tile to the plywood?
I have 5 electical outlets already set at 3/4" - 1" out
Open to any and all suggestions and thank you in advance!
Stcrosby is offline   Reply With Quote
Old 01-01-2010, 12:51 PM   #2
As you saw, clearly I don't know much but I was told that would be fine. Got my first few rows of tile up right now so I hope that's correct!
(Thanks for your responses to my question!)
dahlias987 is offline   Reply With Quote
Old 01-01-2010, 05:53 PM   #3
I believe i found the answer to my own question; I think I'm going to use 1/4" cement backer board applied directly to the sheet rock.
Has anyone had success with this or is cement backer board only to be applied to the studs?
Old 01-03-2010, 01:46 PM   #4
Drywall contractor
You can put the backerboard over the drywall. Tile backsplash is often placed directly on the drywall, because there's not much chance of a lot of water getting through to cause damage. You will need a fairly flat surface though. If the face paper on the drywall has been compromised by removing the old laminate backsplash, it may be easier to add the backer rather than try to smooth out the drywall....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Back Splash Tile Help TTran Building & Construction 15 01-12-2009 04:03 PM
Tile Back splash over stove - Waste of time? Mr Chips Flooring 5 07-06-2008 02:46 PM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 04:16 PM
What size sheet rock for garage ceiling? Billy Boy General Discussion 12 01-24-2008 01:36 PM
Installing A Back Splash bobo Carpentry 3 09-09-2006 03:36 PM
