Attic Staircase - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 04:28 PM   #1
Thumbs up
Attic Staircase
I reside in a 1 1/2 storey home that has a set of stairs climbing to the Attic/Loft area. There are no railings around the opening of the staircase once in the Loft area. Cannot find the codes for the min height or spacing of the uprights to build a protective barrier railing. Or even to build a half wall. I have been told to apply for a permit and submit a drawing of what I am going to install.
Can anyone help?
Thanks,
R
R.Ingley is offline   Reply With Quote
Old 04-14-2010, 07:16 PM   #2
jlhaslip's Avatar
Rewards Points: 2,812
where are you?
code will depend on your location.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-14-2010, 07:22 PM   #3
remodeling pro
Balcony railings of 36" are accepted in most jurisdictions, but I have heard of some local codes bumping that up to 42", even for a residential balcony rail, so it is best to check with local authorities first. Ballusters must be spaces so that a 4" sphere cannot pass through anywhere along the height of the railing.
You have to be carefull if using the typical tapered "candle stick" style, as the spacing at the top just below the handrail will slightly exceed this with two ballusters per 12" tread, which is the most common set up. I have not experienced any trouble first hand, but have heard a few stories of really anal inspectors turning this down.
troubleseeker is offline   Reply With Quote
Old 04-15-2010, 07:24 AM   #4
stair calculator
there are more things than just stairs on this website .. I've found it to be of great help in a number of projects
http://www.blocklayer.com/Stairs/StairsEng.aspx
racehorse is offline   Reply With Quote
Old 04-15-2010, 09:53 AM   #5
Old School
Willie T's Avatar
http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf
Just to make your mouth water..................
http://www.stair****.org/ The four letter word BLANKED out begins with a "P" ends with an "N", and has "OR" in the middle. You will have to help our censor out a little by re-typing it correctly.
(No, it's NOT a bad site! It is some of the neatest stairs you will ever see)
Willie T
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Attic staircase sharp Carpentry 4 12-13-2009 10:40 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
