Attic Ladder That Fits 21 By 27 Inch Opening? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 01:12 AM   #1
Attic Ladder that fits 21 by 27 inch opening?
I need an attic ladder that will fit any opening or one that is made to fit an opening that is 21 inches by 27 inches. I don't think this is a very typical opening size, so I'm having trouble finding an attic ladder.
nathanleg is offline   Reply With Quote
Old 04-02-2012, 06:35 AM   #2
Learning Things Every Day
Jay 78's Avatar
Build one.
Under Construction
Jay 78 is offline   Reply With Quote
Old 04-02-2012, 06:52 AM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
http://www.calvertusa.com/id30.html
sublime2 is offline   Reply With Quote
Old 04-02-2012, 06:59 AM   #4
That's one, but they are expensive. Check out Werners telescoping aluminum ladder. Fits a small opening and takes up little space.
Old 04-03-2012, 06:27 PM   #5
Just a DIY guy
THe bigger question is why is your opening so small?
Unless you have all kinds of structure in the way , you can enlarge the opening. Most times the opening is constructed between the attic joists, with a couple 2x4 spanning the joists to make a rectangular opening.
Before you start, check to see that you have enough room in the attic to enlarge the opening, determine where you want the opening to be so that you know the location where you will be stepping up into the attic (need head clearance, room to step into, etc.), and check to see that you will have enough room for the ladder to unfold and touch the floor, and that you can easily get onto the ladder once it is open (enough clearance from a wall, etc.)
You can leave one of these 2x4 in place to form one end of your opening, but you will have to remove and replace the other one. You may have to move some insulation before you do this, and you will want to put a tarp on the floor to catch the debris. You will make lots of dust too, so prepare for that.
There are lots of DIY instructions out there to show you how to enlarge the opening. WIth basic DIY skills, it's not that hard.
Then you can use whatever ladder will fit in your new opening..
M3 Pete is offline   Reply With Quote
Old 04-03-2012, 08:33 PM   #6
Rewards Points: 6,652
M3 Pete, you want to talk about a small scuttle. Mine is aprx. 16x18, so I can see how the OP is that small.
nathanleg, 18x24 is the min. for the Werner telescoping ladder. How far is it from floor to ceiling? If only 8 feet, stick with a regular ladder. If over 9'-10", you will need a taller ladder, due to the telescoping are not made for anything higher than 9'-10". http://us.wernerco.com/attic-ladders...ries-microsite
Telescoping attic ladder rjniles General DIY Discussions 6 04-05-2012 08:06 PM
So I installed a Telescopic Attic Ladder GGConn88 Carpentry 2 05-11-2010 05:54 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Opening for attic stairs sk8z Remodeling 16 03-17-2008 12:52 PM
