Attic Insulation Advice - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 05:36 AM   #1
Rewards Points: 63
Attic insulation advice
Here's my situation...I just bought my first home about a year ago in Southern Indiana. I went into it knowing it would be a fixer-upper, just not quite this much...but I blame the inspector for that, lol.
I just got up into my attic for the first time a month or two ago and found that I have....wait for it....ZERO insulation (inspector failed to mention that). The ceiling of the room below is drywall on 10" (I believe) center. The roof is corrugated steel over top of what looks like planks and tar/asphalt. The soffits have no insulation, neither does any of the attic. There's currently no vapor barrier between the attic and the drywall ceiling.
Any suggestions on the best way to insulate this attic?
syogod is offline   Reply With Quote
Old 12-08-2010, 06:26 AM   #2
If you have space to get a roll of insualtion, or batts, into the attic between joists, use faced(vapor barrier) 12" insulation. Face goes to the heated side. Otherwise blow in insulation, min 12". Do not cover soffit vents
You could also do a layer of 6" faced insulation, and another layer of unfaced perpendicular to the first. This does a good job of covering any gaps.
Old 12-08-2010, 06:34 AM   #3
Rewards Points: 63
Sorry, I made a typo...instead of "The soffits have no insulation, neither does any of the attic." I should have said, "The soffits have no ventilation, neither does any of the attic."
Does this change your advice at all?
Old 12-09-2010, 04:19 PM   #4
Rewards Points: 590
I would still insulate, but plan on getting your soffits ventilated, in addition to a ridge vent if that's practical. I don't know if the fact that it's corrugated steel makes a difference in that regard.
operagost is offline   Reply With Quote
Old 12-09-2010, 06:59 PM   #5
Registered User
Rewards Points: 5,520
If zip starts 477... R-38 in attic. http://www.ornl.gov/cgi-bin/cgiwrap?...le/ins_fact.pl
Do you have any HVAC units or ducts in attic? May want an un-vented attic if local B.D. allows.... http://www.buildingscience.com/docum...r-all-climates
http://publicecodes.citation.com/ico...006_par003.htm
If you have to use f.g batt, don’t get pinked.
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attic Insulation paige2 General DIY Discussions 21 03-16-2011 10:35 AM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 07:10 AM
Attic Insulation - Do's and Don'ts reikiray HVAC 1 07-27-2007 10:21 AM
