Attaching Two Corner Cut Countertops Together. What Hardware Do I Need? - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 06:24 PM   #1
Attaching two corner cut countertops together. What hardware do i need?
I don't know what hardware to use to attach two corner cut sections of countertop. I will be mounting them on the wall to use as a desk.
jdnoel is offline   Reply With Quote
Old 10-27-2012, 06:32 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
what type of counter top.. laminate?
woodworkbykirk is offline   Reply With Quote
Old 10-27-2012, 07:13 PM   #3
Rewards Points: 13,300
Got a picture?
What do you plan to put under them to hold it up?
Old 10-27-2012, 09:03 PM   #4
I am still thinking about that. I have brackets but dont think they will support. Need galvanized steel adjustable 45-degree hangers I think.
Old 10-27-2012, 09:05 PM   #5
Laminate. So the material is wood.
Old 10-29-2012, 08:58 AM   #6
Rewards Points: 3,130
Are these premanufactured countertop sections? If so, what is typically used is called a draw bolt. Any place that sells the countertops should have them.
Old 10-29-2012, 10:01 PM   #7
I think I was given one of them. They dont lay flat on the surface so how they go on is my dilemma. Hopefully there is some online help.
Old 10-29-2012, 10:14 PM   #8
There installed under the counter not on the top.
Here's some ideas on how it's done.
http://www.mcfeelys.com/countertop-bolts
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
Inside corner on small corner jburchill Drywall & Plaster 0 09-21-2011 11:08 PM
Vinyl Siding Corner Post Obstruction JDPagel Remodeling 4 04-16-2010 01:46 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
