Asbestos Test Kits? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-04-2014, 01:50 PM   #1
Rewards Points: 285
Asbestos Test Kits?
Anyone have any experience with asbestos test kits? I want to test my attic insulation and am considering this: http://www.amazon.com/SLGI-Certified-Test-Kits-Asbestos/dp/B008J3ZK8M/
marcus118 is offline   Reply With Quote
Old 04-04-2014, 05:27 PM   #2
Dark Knight
Streeter1981's Avatar
Rewards Points: 18
Send a message via AIM to Streeter1981
Our home inspector did ours for about $80 I think, and it took a couple weeks to get back. Not sure about this test though.
Streeter1981 is offline   Reply With Quote
Old 04-04-2014, 05:44 PM   #3
Rewards Points: 6,652
What makes you think that your attic insulation has Asbestos marcus118.
Old 04-04-2014, 06:36 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
does the attic have vermiculite insulation? it typically has asbestos in it
ive never heard of home inspectors doing the test, it has to go to a lab for testing,, your inspector probably just took a sample and sent it off somewhere
woodworkbykirk is offline   Reply With Quote
Old 04-07-2014, 06:34 AM   #5
Rewards Points: 285
well i dont really think there is asbestos but would rather be safe than sorry. i'm replacing all the insulation since it's down to 2" thick.
i'm not leaving the old stuff there because the former owners have roof issues, and a lot of the insulation has seen water at one time.
Old 04-07-2014, 06:34 AM   #6
Rewards Points: 285
No. This stuff is from like 1960 when the house was built.
Old 04-07-2014, 01:13 PM   #7
Post a picture of the insulation up in the attic. Vermiculite comes in different forms. It is used in potting soil, but does not contain Asbestos.
Call a couple local places that do testing for Lead, Asbestos, etc. They will take samples of the materials, scrape a little paint to get to the base wall material, then give you a report after about a week.
Everyone automatically assumes that their home or business contains Lead based materials, same for Asbestos, without really the knowledge of what to look for.
I was lucky that when I worked out at our local airport. We had a company that did Asbestos testing. Just talking to one of the lab techs for the company. I found out that our house really only had a danger of Lead based paint under the couple of coats of Latex & Oil based paints, that have been applied to the walls & garage.
I knew that our heating duct work had asbestos tape on it. I just took the proper precautions, to not inhale, or touch my face while taking the tape off.
As for your attic, you should wear a face mask up there anytime, due to the dust accumulation, along with any pollen, mold spores that are free in the air.
Old 04-08-2014, 12:49 AM   #8
iminaquagmire's Avatar
Rewards Points: 338
Vermiculite was mined in the contaminated Libby mine tough 1990 IIRC. If your house is from 1960, it very well could have vermiculite. Its very distinctive, just look at google images and you'll be able to tell if you have vermiculite. The EPA suggests that if you have vermiculite it isn't even worth testing because you can pretty much be assured that it contains asbestos.
That said, lots of products contain asbestos, but I've never heard of other loose fill insulation having it.
iminaquagmire is offline   Reply With Quote
Old 04-10-2014, 12:06 PM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Vermiculite is one of those materials that is listed as PACM........... Presumed Asbestos Containing Material. It's assumed it will contain asbestos until tested and proven otherwise.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
gregzoll (04-10-2014)
late 60's house. Does the stucco have asbestos? pman6 Concrete, Stone & Masonry 9 03-26-2015 07:09 PM
Botched asbestos removal in home... runfrombears General DIY Discussions 28 07-31-2012 09:21 PM
test kits for water ilyaz Plumbing 3 11-10-2010 09:48 AM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
