Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-16-2005, 10:18 PM   #1
ITE
arched opening
what is the best way to frame and install drywall to an arched opening? Im needing to open up part of a wall with a 4x6 opening and wanted it arched at the top. any tips or tricks to make the job easier? what is better, wet the drywall down or cut kerfs in the back of it to make it bend? If you wet it down, how much water should you use and how long should you wait until it can be put on the wall? for the arch I was thinking about making a box by cutting two pieces of plywood in the shape of the arch and sandwiching 2x material inbetween them with an angle cut to match the curve making sure that the whole thing is the same thickness as a 2x4. then attaching plywood to the arch to support the drywall. any tips with using the flexable corner bead? can you joint this up with the rigid metal bead that would be used on the vertical sides of the opening?
thanks for all of the help.
ITE is offline   Reply With Quote
Old 05-16-2005, 10:45 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
arched opening
You've got the framing part down with the arched plywood on both sides with blocks around the middle of the arch.
Don't wet the drywall.
Cut kerfs in the back of it with a utility knife every couple of inches or so and it should smoothly fit under the bottom of the arch. Mud and tape it with paper tape.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-17-2005, 12:09 PM   #3
ITE
arched opening
mike, thanks for the reply,
do you prefer the paper tape on the arch over the flexable corner bead?
when you use the paper, do you just slit it so that it will make the bend or do you cut chunks out of it?
and just out of curosity, why is it better to cut the back of the drywall on the arch instead of wetting it? Ive never attempted this so Im looking into it a bunch.
thanks again
Old 12-08-2005, 12:23 AM   #4
arched opening
Instead of using a strip of notched drywall to do the inside curve why not use a strip of 1/4" plywood and then spead paste with a drywall taping knife. You will get a smooth curve and no corner bead should be needed.
Still_Waters_43 is offline   Reply With Quote
Old 12-09-2005, 05:09 PM   #5
2nd half
arched opening
ITE
I'd get a sheet of 1/4" sheetrock and double it up under the arch, I'd also use the flexible corner bead.
Joe
jmic is offline   Reply With Quote
Old 12-09-2005, 06:14 PM   #6
arched opening
You may want to look into flexible drywall, I haven't personally used it, but Iknow USG sells it
G.P. is offline   Reply With Quote
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 06:11 PM
opening through party wall arise Building & Construction 13 02-16-2007 05:33 PM
Advice on Enlarging a Door Opening WorkOnIt Carpentry 9 02-04-2007 12:53 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 11:50 AM
Frame opening in load-bearing wall joatmon Remodeling 7 11-02-2005 11:48 PM
