Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-18-2012, 09:11 AM   #1
Appropriate overlap of wall around tub
Hello,
I am looking to put up backerboard around the tub to tile on. I had to shim the studs out a bit to get to the tub, but now I am looking at the porject and wondering if i really needed to shim them out as far as I did.
Right now, the shims just (1/16) overlap the edge of the tub. I realized that including the 1/2 inch cement board and then tile and what not. I may be way overshooting how much of an overlap the wall should have with the tub. What is the minimum amount of overlap necessary? I am wondering if I should take out the shims and use thinner ones.
Thanks for any advice!
Jerrys84 is offline   Reply With Quote
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
