-   -   Applying texture on smooth cement interior walls (http://www.diychatroom.com/f15/applying-texture-smooth-cement-interior-walls-38296/)
Flt_Simulation 02-14-2009 12:57 AM
Hope this is the right forum to ask this question:
Hello everyone ... I am a US citizen now living in the Philippines. I am in the process of building a new house here.
Unlike the US, the Filipinos don't stick build houses and use drywall (except for the ceilings). The walls here are made from hollow block and then a smooth coat of cement is applied over the block to make a nice smooth surface.
I would like to have my contractor apply a light orange peel texture to the already smooth surface of the cement walls before the interior walls are painted. They don't sell that powdered texture material here that is added to water and sprayed on like they do in the US.
My Question: The drywall joint compound (drywall mud) they use here is the powdered variety that needs to be mixed with water ... Do you think he could just mix this powder with more water in order to make it much thinner than standard drywall mud and then spray it on the smooth concrete wall just like they spray the texture on drywall in the US? I guess the contractor would need to experiment a little to get the right thickness of this stuff.
I have never seen a paint gun designed specifically for applying drywall texture here in the Philippines. Could my contractor use a regular paint spray gun to do this?
Thank's
Ron (Bacolod City, Philippines)
Here are a couple of photos that show the interior cement walls. The house still has a long way to go, so the construction in these photos still looks pretty rough:
http://i127.photobucket.com/albums/p158/Turbo6ta/43.jpg
http://i127.photobucket.com/albums/p158/Turbo6ta/41.jpg
Architect's computer image of the completed house:
3,210 Sq. Feet under roof (includes covered carport and patio)
2,620 Sq. Feet living area (does not include covered carport and patio)
http://i127.photobucket.com/albums/p...HouseImage.jpg
Termite 02-14-2009 01:10 AM
First, welcome to the forum.
Second, I'm really liking those stairs! Very cool.
It sounds like you're proposing something like a knockdown texture on your walls. To do that, drywall mud is thinned and shot through a texture gun/hopper. Unfortunately for you, that is VERY different than a paint gun. They're very inexpensive (<$50 US) and can be bought online. They're powered by an air compressor.
Honestly I don't know how well drywall mud knockdown would perform on a concrete wall. Hopefully BJBAtlanta...Our resident drywall guru...Will chime in on that.
Maybe you could use the same hopper to spray a portland cement slurry??? I've never tried it but it really might work.
Another option you might consider is a stucco-like product like EIFS or Dryvit. Some of those have some grainy texture.
Termite 02-14-2009 01:13 AM
By the way, it would be really cool if you'd start a thread in the PROJECT SHOWCASE section of this forum to show your new home under construction. As you know, this isn't typical construction methodology for the US, and a lot of us would find it interesting to see it come together.
Flt_Simulation 02-14-2009 01:33 AM
That was a real fast reply ... Thank's!
I really didn't want a knockdown texture .. Just you basic light coating of 'orange peel' type texture.
Flt_Simulation 02-14-2009 01:39 AM
Thank's for the idea .... I have photos from start of this project to where it's at right now ... I could certainly do that soon.
Ron,
BTW .... Here are a couple of simple sketches showing the 1st and 2nd floor plan:
http://i127.photobucket.com/albums/p...an1stFloor.jpg
http://i127.photobucket.com/albums/p...an2ndFloor.jpg
bjbatlanta 02-23-2009 06:57 PM
Sorry to take so long, been out of town. Quite an impressive house! I don't think I would consider drywall texture on concrete IF IT WERE MY HOUSE. That said, I have used drywall joint compound with paint mixed in for "block fill" at the contractor's request. I have seen "popcorn" texture sprayed directly on concrete ceilings in hotels/motels. I would just be a little leery in the climate you are in. I may be wrong, but to me the Phillipines brings to mind a very humid enviornment. Concrete brings to mind a surface that could "wick", retain, absorb moisture. That would tend to make any type of drywall texture turn loose (in my opinion). And I may be oversimplifying things a bit. I'm guessing you'll have an HVAC system, but I don't know if it will be used a lot?? And I'm sure whatever texture you would use would be painted to seal it. It just doesn't seem like a good idea....... You might want to go to a site like United States Gypsum (USG.com) and see if they even specify whether any of their texture materials can be used on concrete surfaces. If they do, a hopper is pretty cheap. I tend to think KC is on the right track though with the idea of using a EIFS type system???? Sorry to be so evasive, but if you asked me to do the job, I would on the condition I didn't have to warranty it. Or at least that's my opinion without some further research and assurance from a mfgr. that would stand behind the process.
Flt_Simulation 02-24-2009 05:33 PM
Thank's everyone for all the replies.
bjnatlanta .... You may be very right. In fact, I have not seen any texture (to include simple orange peel) used on concrete walls here in the Philippines.
I showed my foreman a photo of one of those $50 - $90 texture spray guns with a plastic hopper on the top I downloaded from the internet. He took the photo to several stores here that sell paint and drywall. Nobody had ever seen one ... so I guess that tells you something.
They don't use drywall on walls here since all interior walls are made from hollow block covered with a smothh coat of cement ... However, thety do use drywall on interior ceilings. You can see the metal grid (frame they attach the drywall ceilings to in one of the photos I posted above.
Anyway, thank's for all the info.
Ron,
bjbatlanta 02-24-2009 07:21 PM
I'm guessing they frame the ceilings to hide the HVAC, plumbing, electrical, etc. How about wall outlets and such?? Run in conduit on the surface? As KC said, I'd really like to see some pics (especially interior) as you progress if possible. That's one heck of a structure as residences go......... The radius stuff is poured concrete?? And the architect's image is great! Looks like you're right on a body of water? Keep us posted if you can, I'd really like to see more. Just one last idea, there's a guy who posts on here a lot who might be able to give you some insight into options. If I remember, he goes by "yesitsconcrete". Type a "concrete" question in the "search" box at the top of the page and I bet you'll see his name in there somewhere on a topic. He seems very wise in the ways of concrete. I'd be willing to bet he could give you some answers as far as texture materials that will work. At any rate, best of luck with the house and keep posting pictures if you can!
Meggie929 05-14-2009 05:23 PM
Your House In Bacolod City
I would love to see more photos of your house. I will also build a house for my mother in the same area, probably middle of next year. Thanks for your posts and thank you to those who replied to your questions. I'm learning a lot from it. By the way, I don't have a contractor in Bacolod yet. Can I ask who your contractor is? I hand-drawn my floor layout and I will have to show it to an architect from there. But I don't know any architect or contractor in that area. I am actually from that place but I am now residing in Texas.
