Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-16-2012, 12:59 AM   #1
Anyone used Redi Niche
Has anyone used Redi Niche premade shower niche? Has it been easy or difficult to use? I am building a shower with durock panels.
darsunt is offline   Reply With Quote
Old 11-16-2012, 01:39 AM   #2
funfool's Avatar
I say go for it!
I have built many from hand because of necessity, while sometimes using a prebuilt worked fine.
If a prebuilt works for you, I say go for it.
If you have some custom needs, then may be better to build yourself.
But different brands I have used in past were fine and a time saver.
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
Old 11-16-2012, 01:39 AM   #3
I've never used one. Check this out for some reviews. Just look at the very bottom of the listing.
http://www.amazon.com/s?ie=UTF8&keyw...20redi%20niche
Old 11-16-2012, 07:10 AM   #4
Super Moderator
I've never used one---It seems to me that the flange would cause a bulge under the Durrock and make for a difficult tiling job. Also---waterproofing would be needed where the plastic pan meets the Durrock---
I build my own and waterproof them with Hydroban----
Where to put the tile niche in the shower? DimeBag1976 Tiling, ceramics, marble 16 12-21-2011 10:17 AM
Square drain plate for Tile Redi shower gagler Kitchen & Bath Remodeling 4 08-28-2011 10:51 PM
Custom Shower, Soap/Shampoo Niche acerunner Tiling, ceramics, marble 3 03-01-2011 07:05 AM
low voltage wiring for niche lighting 8roty Electrical 4 01-16-2010 08:17 AM
Building shelves into a niche joelq Carpentry 6 01-04-2010 02:25 PM
