Anyone Experienced Cutting Granite? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-09-2007, 10:25 AM   #1
Anyone experienced cutting granite?
We have an outfit in town where a person can purchase pre-finished granite countertops, 26" deep with a full bullnose edge. I would like to install these myself if possible.
My application is very simple, no seams. I would only need: two slabs, both will need to be cut to length and one will need to have the sink cut out.
Is this something I can do myself?
What type of blade would be recommended for this?
What type of adhesive would I use to secure to the cabinet tops?
Thanks for any advice.
Bigman610 is offline   Reply With Quote
Old 03-09-2007, 11:14 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
From this website:
http://www.marblemaster.com/granite/..._slab/faq.html
Q. How can I cut granite slab? Do I need special tools?
A. Granite slab can be cut with a standard household skill saw fitted with a continuous diamond cutting blade. These are available from Home Depot and Lowes for about $40.
Q. When I cut certain kinds of granite I noticed the sharp edge of the granite wants to chip away and I don't get a clean cut. Is there anything I can do to get a nicer cut?
A. It is a trick used by the professionals. It is called "collar the blade". These are sold in the tool department of most major hardware stores. They are really giant washers that you place on both sides of the blade when you install it on your skill saw. The chipping is usually caused from vibration of the blade as it is cutting. The collars reduce the vibration and the resulting chipping of the edge.
Q. What do I use to glue the counters in place?
A. Clear knife grade 2-part epoxy works great. Use this same glue to seam the edges where the slab panels meet. When doing your edges add some color pigment to the epoxy resin before you add the hardener which make the epoxy glue set up. These color pigment kits are available from Home Depot or Lowes in the paint department and cost $10 to $20.
You can check out that site for other more helpful information.
- Build Well -
Old 03-09-2007, 12:26 PM   #3
Thank you for the help and information Atlantic, it is appreciated.
Old 03-09-2007, 04:08 PM   #4
U R Welcome ... and good luck
- Build Well -
Old 05-04-2007, 02:16 PM   #5
be really careful in cutting granite yourself. Mistakes can be very costly. If you trying to cut costs you may want to consider have a supplier cut the granite for you and do the installation yourself. Measure twice cut once!
BILZ is offline   Reply With Quote
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 07:18 PM
Decorative Etched Granite Listello csteinke Remodeling 1 06-09-2007 12:54 AM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 09:53 AM
granite counter top cutting trifit1 Remodeling 2 02-12-2006 07:56 PM
