Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-27-2008, 01:50 PM   #1
Any Tips on Installing Plastic Molding?
I'm looking at using pre-primed plastic base molding. It'll be my 1st time trying to use it, and am wondering if there are any
- tips or
- recommendations or
- gotchas
on installing it?
For example,
- What's best blade to cut it with? Can I cut it with a power saw or must one use a fine-toothed hand saw?
- Can I rip it to adjust it's height?
- Is there anything I need to do (more than normal) for the joints in the run?
- Are butt joints or weather joints preferred on a run? Mitered or coped inside corners?
- Can I nail it up with an air gun? ...or does it need to be pre-drilled and then hand nailed?
- Is/Are there a preferred putty product?
Thanks for your help!
1655graff is offline   Reply With Quote
Old 11-28-2008, 10:07 AM   #2
For the most part, it works much the same way as wood or mdf moldings. It is a little more fragile, and can break easier, just make sure you use at least an 80 tooth blade in your chop saw.
You can use an air nailer, just set the pressure down or you'll shoot right through it.
NEVER use a butt joint in a long run, whether you're using wood, mdf or plastic. Those never turn out as nice as a mitered joint, always more noticable.
I tend to just mitered inside corners more often, especially when painting. Coping just takes too long. I usually only cope when the corner is too far off and leaves a gaping, uh, gap.
Just use plain old paintable caulk for all joints and nail holes.
Jeeper1970 is offline   Reply With Quote
Old 11-28-2008, 10:12 AM   #3
Drywall contractor
I've used composite 1"x for exterior use and 3/4" round on kitchen floors. No problems with nailing with a gun. I use a 60 or 80 tooth blade in the miter saw, it works fine. Same with ripping, use a fine tooth blade. I cut the joints on a 45. For actual base I would cope (though I haven't used any as yet). I think it would cope just fine. I use regular latex caulk.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-28-2008, 10:19 AM   #4
In way over my head.
Clutchcargo's Avatar
What kind of plastic is it?
I got this plastic moulding from HD that I was planning to use in an exterior application. I thought it was PVC but it turned out to be something else. I tried using my miter saw to cut it and it made a melted mess and melted plastic to the blade. I returned it to HD and bought Azek instead.
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
Old 11-28-2008, 08:36 PM   #5
Wow! Thanks everyone.
Yes, I saw the HD brand too, but am thinking of going with Lowes' "evertrue" brand.
More On This Topic
Replacing your windows is one way to boost the value of your home, especially if the new windows are more energy efficient. One of the popular styles of replacement windows is vinyl retrofit replacement windows. Read this eHow to learn how to trim... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cope crown on an inside corner. The reason that you might cope crown molding, is that sometimes your walls maybe out a little bit, your angle... Read More »
I don't have a sample of mdf I can tell you about it. Mdf is sawdusting glue that is put together in a vac and it is injected into a mold. They send it out into mold shape. I don't use mdf cause it tears up my saw. It is very difficult on the saw, it... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we will be demonstrating how to cope a base on a 90 degrees corner with a miter saw and a coping saw. When you are coping in base, it really allows you to get a super tight corner... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cut an inline joint with a miter saw in crown molding. You might think that cutting your corners at the compound miter setting that you would... Read More »
tips for installing Provent insulation baffles? txdiy2607 Roofing 4 07-03-2008 06:03 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Wainscot molding issues cmdrico7812 Remodeling 2 02-01-2008 01:54 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
Installing Crown Molding fmolden Carpentry 6 01-08-2008 11:09 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
