Any Reason To Tear Out Old Lath-board Knee Walls? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 06:10 PM   #1
Rewards Points: 264
Any reason to tear out old lath-board knee walls?
Hello,
I am redoing my attic, which used to be finished with water-damaged, lath board plaster. The plaster is wrecked in places so my plan is to rip it out and hang blueboard. However, the knee walls are in good shape - I was wondering if it would make sense to leave them and just replaster? It would save a little in materials, and a significant amount of time both in the demolition and rehanging. It seems a little half-assed, but I can't really see a downside. I even thought of hanging blueboard right over the knee-walls, but I don't see why it would be necessary.
Thoughts?
tibberous is offline   Reply With Quote
Old 03-26-2010, 05:54 AM   #2
I assume you are using blueboard because you are plastering??? If there are large gaps in the old plaster, I would fill them with drywall mud, then go over with drywall, blueboard, etc. Make sure you screw into the studs, not just the lath.
Old 03-27-2010, 02:12 AM   #3
Rewards Points: 264
Lol - yeah, I'm not THAT bad
I might try plastering, might just sub it out at that point.
airblocks underneath knee walls bob with 4 dormers Building & Construction 6 02-17-2009 10:52 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Acrylic shower walls, cement board needed? SDG Plumbing 3 10-01-2008 07:05 AM
Walls on top of particle board that got wet Bruno2000 Flooring 2 08-24-2007 02:30 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
