Any Experience With Roxul? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 11:54 PM   #1
Retired & Not Likin' It
Jim McClain's Avatar
Any experience with Roxul?
My landlord is also my oldest and dearest friend and he lets me do whatever I want. I recently remodeled the kitchen/living area and will be starting the bedroom soon.
There's one wall that is the common wall with the apartment next door and there's no insulation. Temperature isn't the problem, but sound sure is. Currently there's a young person with an active social life living there and I don't really wanna hear it.
My plan is to remove the sheetrock from my side of the wall and put some sound deadening material there. My research tells me that a product called Roxul Safe'n'Sound is what I should give serious consideration into using.
I hope some of you have some experience with the product and can offer your opinion. One of my concerns is the dust and fiber aspect of the raw material. I have late stage Emphysema and am on oxygen 24/7. I can work for short periods of time (for instance, the 2 week remodel of the main room took me 8 months ) and I don't mind wearing a respirator, but it's difficult.
Please don't suggest hiring someone. I can't afford that. My only choices will be do it carefully, or don't do it at all. I'd like you to share your experience with handling the product so I can make that decision.
The wall is about 12' long and 8' tall. If I can manage that project, I will prob'ly do the bathroom wall at a later date - it's also about 12x8'. I have some experience. I have done a bit of new and remodel construction over the years and did flooring for 35 years.
Best R'gards,
Jim
Jim McClain is offline   Reply With Quote
Old 02-23-2010, 01:19 AM   #2
Heritage Restoration
Roxul is great stuff.
Blows Pink out of the water. Also doesn't have a cancer warning like Pink does.
Skuce is offline   Reply With Quote
Old 02-23-2010, 02:20 AM   #3
Thanks, Skuce, but what about the other properties? Does it have a lot of loose fiber and dust like the pink stuff? That's my main concern.
R'gards,
Jim
Old 02-23-2010, 05:36 AM   #4
Rewards Points: 85
If you are going to go through the trouble of ripping down dry wall and installing Roxul, you might also want to look into sound deadening drywall that is equal to I believe 8 layers of drywall with their different layer of films within the thickness. I watched an episode of Holmes on Homes when neighbors in your situation were having the same problems.
mferguson0414 is offline   Reply With Quote
Old 02-23-2010, 10:42 AM   #5
It's a lot nicer to work with. It's not picky and doesn't fall apart like Pink. It also doesn't turn to crap if it somehow gets wet.
I swore off using Pink probably 10 years ago now.
Old 02-23-2010, 03:10 PM   #6
Out of all the mineral wools Roxul is the nicest one to work with. It can be a bit prickly and dusty though why don't you suggest to your young neighbor that they give you a hand installing it otherwise get a really good respirator
parts is offline   Reply With Quote
The Following User Says Thank You to parts For This Useful Post:
mferguson0414 (03-05-2010)
Tags
insulation , roxul , sheetrock , soundproof
roxul insulation ctkeebler Building & Construction 15 01-09-2016 05:54 PM
Nansulate HomeProtect - any thoughts or experience with it BimmerRacer Green Home Improvement 5 08-28-2009 09:51 PM
Anyone have any experience with cabinetliquidators.com? skipjack Remodeling 3 04-07-2009 10:08 AM
Anyone have experience with Nature Exotics? JDeFuria Flooring 8 03-10-2009 06:08 PM
Non-Gas powered mowers. Experience? Thoughts? IckesTheSane Landscaping & Lawn Care 3 12-03-2008 01:04 PM
