Andersen Casement Window Stuck At Top - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-16-2010, 05:37 PM   #1
Andersen Casement window stuck at top
I have a bay window that has has Andersen casement windows (the kind with the crank handle to open/close them). One of them gets stuck at the top only when trying to open it. In other words, when I crank the handle, the bottom starts opening but after a few inches the stuck top edge holds it back. All I need to do is give it a mild bump with my hand towards the top of the window and it gets unstuck.
Problem is, I'm selling this house and the buyers noticed this problem and want it fixed.
How do I fix this? I looked for some sort of adjustment screw but didn't see anything. I can snap a pic if it will help, but basically the casement window is about 45" tall by about 18" wide. It sticks at the top edge opposite of the hardware/hinge side.
mark2741 is offline   Reply With Quote
Old 04-16-2010, 05:38 PM   #2
One more thing - the problem definitely is not paint. It's all weatherstripped and new pvc/plastic coating on everything. The windows were installed by the previous owner about 5 years ago, so they aren't old. I'm guessing that the house shifted a bit and the opening no longer is square with the window. What can I do?
Old 04-22-2010, 03:31 PM   #3
Rewards Points: 5,336
The bay window was not adequately supported when it was installed. It is now dropping down, binding the sash. Go outside and raise the bay and put in the proper support and the windows will work properly.
Ron
Old 04-22-2010, 04:21 PM   #4
Or sand off the interfering area with a belt sander or file or small arbor-mounted grinding wheel run with your elec. drill.
You may need to remove only a few thousandths, if you find the right place.
Old 04-22-2010, 06:03 PM   #5
Andersen casements are cased in vinyl. You would sand right through the protective vinyl to solve the problem and create another.
The only fix is to lift the front edge and add support.
Ron
Old 04-22-2010, 06:16 PM   #6
kwikfishron's Avatar
Rewards Points: 618
Andersen casements are also notorious for hardware issues, especially if used a lot. I’d at least check the frame for square before jacking anything around.
kwikfishron is online now   Reply With Quote
Old 04-22-2010, 07:25 PM   #7
DIY staff
Rewards Points: 7,174
Anderson bays and bows are suspended from the soffit (rafter tails) using a cable and turnbuckle.
If lifting the window is needed you will need to remove a piece of soffiting to expose the cable and turn buckle. they are located where the outside windows meet the center window.----------------
--measure the windows corner to corner---see if they are racked.
Old 04-22-2010, 09:29 PM   #8
Ron
I should have asked for a photo or a link; my bad.
Old 04-23-2010, 06:25 AM   #9
This is one option of support. Many bays are supported by supports under the bay.
As kwikfishron said, you would first check for out of square before you did anything. You would also need to know exatly what your doing so you don't crack the glass.
Ron
Old 04-23-2010, 07:17 AM   #10
Rewards Points: 618
I have to say I gave up on Anderson a long time ago. There’s basically only two things that can be happening. #1 Installed wrong, or #2 Hardware frailer (or mabey framing moving). Living on the Coast with all the Salt Air we experience a lot of #2. For the most part I can figure out that the window needs, a new this or that and looks easy enough to replace. The problem for me is by the time you think you’ve got past the language barrier with the inexperienced sales rep on the phone, 2-3 weeks later the wrong part arrives. I have a customer who comes to me with what on the surface is a simple problem and now I’m looking like a idiot for what should be about one billable hour. If it’s a installation issue I can see that and fix it. If it has to due with parts, I (now) hook the customer up with the Anderson Service Dept. Usually in less time that it takes to get the wrong parts they’ll have their issue fixed. Primarily because Service Guy has all that stuff on the truck.
Oh and one more thing, you better be sure it’s a hardware issue and not a another problem if you call their Service Dep. because Anderson will walk away if they decide the window was put in wrong and bill you for that fine advice.
Old 04-23-2010, 09:06 AM   #11
Thanks everyone. I just went ahead and sanded it down and rubbed some candle wax onto it and it's not nearly as 'sticky' as it used to be. I'm 99% sure that the frame has gone out of wack. This is only a 5-year old bay window but based on the other contract work that the previous owners of this house did, I'm sure this window wasn't framed out/installed by a quality contractor. I sold the house and just want the window 'unstuck' for the final walkthrough, so changing out hardware/reframing/etc ain't gonna happen on my watch : (
The Following User Says Thank You to mark2741 For This Useful Post:
oh'mike (04-23-2010)
Replacing crank on Andersen Casement Window pjmhuffman Windows and Doors 3 09-27-2014 03:29 PM
Removing Glass of Casement Window JPM General DIY Discussions 3 02-09-2010 10:16 AM
Casement window doesn't close all the way jasontal Building & Construction 1 08-23-2009 08:23 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
