Anchor Wall To Concrete Floor - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-16-2007, 08:38 PM   #16
Hello all, I was wondering when installing the Tapcon screws is a Hammer drill required? If so, which one do you recommend? I recently looked at some prices and they are pretty expensive.
Thanks,
Stingray is offline   Reply With Quote
Old 03-16-2007, 09:43 PM   #17
yummy mummy's Avatar
Rewards Points: 1,016
Hi stingray
Yes, the hammer drill really is required in order to drill through the concrete.
I have a Ryobi, which is really not that expensive but I find does the job well.
yummy mummy is offline   Reply With Quote
Old 03-16-2007, 09:45 PM   #18
Cool, thanks for the info yummy, guess I am buying one tomorrow.
Old 03-16-2007, 09:46 PM   #19
Great, I hope it works well for you.
Old 03-16-2007, 09:49 PM   #20
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by yummy mummy View Post
Hi stingray
FWIW - Just confirming this - Y.M. is absolutely right about this. Don't try to do this using a normal drill and 'tapping' alot of holes....
(Y.M. -Glad to see you are up and still contributing here - )
- Build Well -
Old 03-16-2007, 10:08 PM   #21
Thank you for the help guys. Atlantic, just reading around the board here, I see you're a big advocate of the 2 inch spacing between the freezewall and studs, which I think is a smart idea.
I do have a question about the vapor barrier. I have a very dry basement and had a contractor come out and said the plastic sheeting should be applied directly to the poured concrete walls. I think he is wrong, and after viewing all of your posts I am now going to apply the plastic outside of the insulation and studs. How do you attach the sheeting to the studs?
Sorry , I am a bit of a newb here.
Old 03-17-2007, 12:15 AM   #22
atlantic
Oh, oh, that dreaded vapor barrier question!!!!!!!
Boy, have I come a long way atlantic. I can even answer some of the questions now.
Stingray:
Don't be sorry that you are a newb. A lot of us are here.
But before you know it, you will be answering some of the questions, I'm sure.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
concrete floor hate_monet Flooring 5 08-13-2007 04:09 PM
vapor barrier over concrete floor cricket1 Flooring 22 05-31-2007 09:41 AM
Leveling concrete floor - problem McCool Flooring 3 12-05-2006 09:31 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 04:13 AM
