Aluminum Sunroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 11:12 PM   #1
aluminum sunroom
Is it possible to drywall my aluminum sunroom? I want to improve the insulation and reduce outside noise.
Malasadas is offline   Reply With Quote
Old 01-27-2012, 11:40 PM   #2
Rewards Points: 14,026
Need some pictures, where do you live.
Drywall will not the deaden the sound hardly at all.
Most of the sound would still come in though the windows.
Old 01-27-2012, 11:55 PM   #3
I live in Southern California. Insulation is my primary objective, but if you have any ideas for the sound through the windows...I'm open ideas!
Old 01-27-2012, 11:57 PM   #4
Without a picture no one is going to be able to suggest anything.
Old 01-28-2012, 07:06 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,264
using rockwool insulation and 5/8 drywall will help a bit, spray foam and sound board will do even more. but as joe mentioned your current windows wont do much. if you want to reduce the sound transmission quite a bit you will have to upgrade your windows to one that has a stc rating
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Malasadas (01-30-2012)
Old 01-30-2012, 08:02 PM   #6
Thank you. Having difficulty uploading the picture, but I think you answered my question!
Aluminum siding not matching after Door install alcopaulic Building & Construction 1 09-07-2011 08:46 PM
Cutting Aluminum Panel in Sunroom? parisvienna General DIY Discussions 4 06-15-2010 05:12 AM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 11:19 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
