Aluminum Storm WIndows - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-04-2010, 01:52 PM   #1
Question
I have 30 year old aluminum ext. strom windows that slide up and down with a screen in between. They are mounted over the original wooden windows. I would like to know if there is a more "modern" energy efficient
storm window that would mount in place of these old aluminum ones? I would like to keep the screen option as well, the original windows do not have screens.
21rocket is offline   Reply With Quote
Old 07-04-2010, 08:19 PM   #2
Rewards Points: 5,336
Newer strorms will not have a much better efficiency then the ones you have. The price point for a new storm would be better used for newer windows.
What type of windows do you have now?
Ron
Old 07-05-2010, 06:10 AM   #3
Storm windows
The windows are original 50plus year old single pane wooden windows... I really did not want to tear out the originals and have to mess with the vinyl siding or the trim inside.... so in response, I have double hung single pane OLD windows... there are ten of them on an inclosed porch
Old 07-05-2010, 06:26 AM   #4
There are sash replacement kits availabe that only replace the sash and add a jamb liner, Marvin or Weathershield. And vinyl replacement windows do not require removal of the old frame, but the storms have to be removed.
Old 07-05-2010, 06:37 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
http://www.harveybp.com/storm_windows.aspx
try here
id rather see good storms installed than crappy prime units anyday
Tom Struble is offline   Reply With Quote
Old 07-05-2010, 07:35 AM   #6
Is this porch heated or cooled or a three season porch? If it's a 3 season porch, why bother with the storms.
As stated by Bill, you can install a good quality vinyl replacement window and get the efficiency you want without touching the exterior.
Ron.
Old 07-05-2010, 03:18 PM   #7
aluminum storms
The porch is heated with HWBB...4 season and used alot.. it is the primary entry to the home.. just looking to get a little better seal so we do not get the condensation or breeze.
Old 07-05-2010, 04:20 PM   #8
Is this porch over a crawl space? Unheated? Uninsulated?
Ron
Old 07-05-2010, 06:35 PM   #9
aluminum storms
Yes the porch as attached and there is no foundation under it....
Old 07-08-2010, 07:31 AM   #10
I started in the window industry after high school 30+ yrs ago building storms. I am still in the industry, and our company still offers storm products. They look and perform about the same mechanically.
The difference is that some storm manufacturers will offer tints and even hard coat low e to improve performance. This will lower the U value of the combined prime/storm product.
I believe that someone mentioned replacement windows in this thread. The old wood sash can be removed and a replacement put in its place. The old wood would need capped to reduce maintenance.
Hope this helps in your decision making process.
fenestrationman is offline   Reply With Quote
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 11:19 AM
Security Storm Windows lgleasain General DIY Discussions 0 11-08-2009 03:05 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 09:07 PM
